The service manual for the Jenn-Air JGS8750AD* series says 'Control Not Calibrated' 'Replace Control.' I've replaced the control and get the same error. What is it calibrating? I can find no further explanation of what it is doing. Help & Thanks!
New front panel (Can't get just the membrane) and the original EOC /ERC board fixed the problem. Replacement board(s) (two) had same error with new front panel, but then the timer and number buttons worked the way they should before it returned the 'F1-E' error.
You can't post conmments that contain an email address.
F1 means defective control module. On manual it will be: "Electronic oven control failure"
From manual:"Replace electronic oven control (also called EOC or clock)."
Try disconnecting power cord or tripping the circuit breaker for a couple of minutes. If the error comes back you will need to replace the oven control module.
F1 - E1
EEPROM checksum error
1. Disconnect power for at least 30 seconds. 2. Re-apply power and observe for at least one minute. 3. If code re-appears, replace control board (also called ERC or clock).
Hello,Please use the chart to determine which stove you have. You will have
to look at the model number. The first 3 numbers will be the series on
the chart. In most cases an F1 error would require replacement of the
electronic control. This part is commonly refered to as an EOC or ERC.
However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric) F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper) F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool) F1-E0 EPROM Error - Electronic Range Control (ERC). F1-E1 EPROM Error - Electronic Range Control (ERC). F1-E2 U/L ERC Errors - Electronic Range Control (ERC). F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric- “9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire) F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error. Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Hello, please use the chart to determine which stove you have. You will have
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE - 790 Series Electronic Oven Control (Frigidaire) F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error. Runaway Temp = Replace Electronic Oven Control (EOC).
Nope, it clears the code, but then comes back in about 20 seconds.
