Question about Dell PowerEdge Computers & Internet
My poweredge 830 powers on but no signal to monitor
    New Friend:
    Problem Solver:
  • 7 Answers
Step 1:
First open look on the back off your pc and see if you have an onboard video card (closer to the power supply and pointed up and down or one much lower down towards the last two-thirds off the case....
Step 2:
If you have an onboard I would think it's toast but if you have a seperate video card swap it out for another one and if that don't work I would guess it's your motherboard.....
Posted on Apr 05, 2013
6ya staff
SOURCE:
Complete backup of Dell PowerEdge 830
make sure to 'take ownership' of all files with your Windows 2008 account before transferring. (or your AD account if you guys use AD) note: you can only do this with an adminstrator account. Take Ownership of File or Folder
Apr 17, 2014 | Dell PowerEdge 830 Server
A power outage cause dell server 1600sc to shut down & no display on the monitor
Hello here is the homepage.
http://www.dell.com/support/drivers/us/en/ussoho1/Product/poweredge-1600sc
There should at least be a message on the monitor indicating there is no signal coming to the monitor. The first thought that comes to mind if all is connected would be that the power supply has failed.
And maybe the graphic card.
Call also the DELL support in your country they will be glad to help
and they probably know the fault.
Contact Us 1-877-671-3355
Good luck
Nov 16, 2012 | Dell PowerEdge 1600SC Server
Fan too noisy
Check the power connection and also clean the fan.
Aug 06, 2012 | Dell PowerEdge 830 Server
Dell poweredge 830 cd-rom unknown bios
Enter the set up (BIOS) menu by tapping the F2 key. Hold down the <Alt> key and depress the <E> then the <F> keys in succession. This will force the motherboard to load default settings and also force the motherboard to redetect all IDE devices. Note: The selection for the floppy drive will be set to ON. If you do not have one then you must disable floppy in set up (BIOS) menu.
Apr 13, 2012 | Dell PowerEdge 830 Server
How do I open my power edge to replace RAM. I t looks like it is riveted in back
You can conveniently crack open the case without tools by swinging open the door that covers the front bezel, using your fingers to untwist a setscrew that lies underneath, then sliding off the side panel
Jan 01, 2011 | Dell PowerEdge 830 Server
On a Dell Poweredge 830 server C: drive is full while F: drive has 238 gig available. How do I get data to go to F drive.
first I would try a "disk cleanup" to remove any un-necessary files and to compress old files. this should provide more free space. if you still need more space you can just drag and drop files from the c drive to the f drive, just make sure you don't get any system files or anything under the "program files" directory. to perform a disk cleanup double click on the "my computer" icon on your desktop, right click on the c drive and go to properties. you will see the "disk cleanup" button on the bottom of the general tab. click on that and follow the instructions to do the disk cleanup.
Nov 01, 2010 | Dell PowerEdge 830 Server
Dell poweredge 830 server orange flashing light instead of solid blue. No fault on screen. any ideas?
its the cover switch. there is a small push switch on the front panel that detects if the front cover has been removed, either the switch is defective, or the cover is not seating properly to close the switch.
Jun 09, 2010 | Dell PowerEdge 830 Server
Problem
This server direct not boot by windows cd....
and u any time install window u lose the all data....because they have scsi hard drive and configuring bydefault Raid 5 ......so plz make backup before u start this prosiger.......Dell providing u lots of cd's check it this cd "installation and server management" bootable cd put this cd into your cd rom drive...and i am giving u link that how to complete install window in this server.
http://rapidshare.com/files/175988908/how_to_install__os_-_window_storage.doc.html
Sep 18, 2008 | Dell 2.8 GHz Second Processor for...
Error
NTDETECT is the system boot file. Something has corrupted it. There is no way to boot the system if it can't read this file. If you have the windows disk, boot from that. The easiest thing to do if you have the disk is just to re-install windows. If you do an upgrade over top of itself, you will probably save your data. If you don't have a windows disk, get one.....
Sep 17, 2008 | Dell 2.8 GHz Second Processor for...
Open Questions:
Computers & Internet Logo
110 people viewed this question
Ekse
Clive
Clive
Alun Cox
