The click you are hearing is most likely the start slenoid making contact, however you should short the large wires @ the solenoid to make certain the starter still doesn't run, if so try tapping the starter with a hammer to shift the comutator a litle and try to start. Even if it now starts the starter will continue to give you problems so the proper fix is change the starter
Grab a test light go down to the starter, hook to a good ground and probe the battery cable. If that has power probe the solenoid engage wire( its the little one) have a helper turn the key to start if that gets power replace the starter.
Know this problem was posted several years ago, but having same issue with my 2008 Nissan Rogue. We've tried everything short of having the battery replaced, (including charging it), and nada. So, tomorrow morning, that'll be our next move. Sucks, but best thing to die. Much rather than than an alternator, starter or solenoid.
Well the good news is the click indicates the switch is working, when you press the switch the 2poles on the solenoide are joined together alowing the current to the starter,bridge the wires at the solenoide this should put power directly to the starter you wont need to press the start switch, if the engine does not turn over check the connections to both the battery and starter motor,
this could be as simple as a bad battery have you tryed to jump start it? if you try and that dosent work make sure you have power going to the starter with jumper cables on the battery. it should at the very least make a clicking sound while trying to start it check the battery posts also make sure they are clean and if it does click give it a minute and try starting it again.[ dont take the cables off the battery while waiting] the fact the starter doesent even click when you try to start it tells me no power to it or bad starter remember just because its new dosent mean it works i cant tell you how many times i have put somethig on a car and had to take it back off because it didnt work from the boxx new. and make sure the starter wires are tight and clean. if no clicking and you have power to starter then starter is bad.. i hope this helps..
