You have disabled wi-fi so it is asking whether you wish to use Phone Data Connection instead. (Standard Practice when trying to access data services)
What you need to do is un-tick the option in options Use only 2g networks. (3g is the mobile data service) That should then allow you to access Mobile Data. (3g)
• If you want to use a USB cable connection, you must first install Microsoft ActiveSync version 4.2 or later on the computer. • Before using Internet Sharing, disable ActiveSync on your computer. To set up your device as a USB modem 1. On your device, tap Start > Programs > Internet Sharing. 2. In the PC Connection list, select USB. 3. In the Network Connection list, select the name of the connection that your device uses to connect to the Internet. 4. Plug in the USB cable between your device and the computer. 5. Tap Connect. To end the Internet connection • On the Internet Sharing screen, tap Disconnect.
by your no., it seems that you're a subscriber od bsnl UP-E.. you can do the settings as mentioned here > http://www.bsnl.co.in/wap-web/dsn.htm & do the settings by start > settings > connections > connections > Add a new modem connections..
BSNLGPRS supports HTC windows based Mobile
Here is the Procedure to acessGPRS in your HTC
Go to Start- Settings > Connections >Connection >(Under internet settings select)Add a new modem connection
Enter a name for the connection:BSNL (you can type any name as you like) A modem(from the drop down list select)Cellular Name(GPRS)
(On the bottom of your screen select):Next
Access Point Name(APN):gprswest.cellone.in (gprwest or south depending on your location
Press : Next User name: Leave it blank Password: Leave it blank Domain: Leave it blank
In the bottom line press: Finish
(Make the connection BSNL default indicated by this sign @)
Here setting is finished.
TO BROWSE INTERNET . . . . Method 1
Press Start Internet Explorer Enter url/site name which you want to browse. Method 2
Under internet settings click on Manage existing connection.On your screen BSNL
(the name you had given will be shown)with the Joystick/Stylus(the stick coming along with the handsets).Tap and hold on the name i.e.BSNL,two sub menu will be displayed i.e.Delete and
Connect,click on Connect.
Please Observe the symbol of “E”or G .In HTC a small E comes out of E.
Note:Always keep only one connection setting i.e.BSNL and use method 1 as it is simple.If you have only one connection directly start browsing by method 1 as and when you want to browse the internet.
Hi for the GPRS setting you have to add a new connection by going into the settings menu and after that for server and port information you have to contact BSNL customer care as they only would be able to guide you regarding server and port number and after that you can connect to internet using EDGE available in your phone.
i am elamurugu. i connect the htc mobile with bsnl cellone GPRS as following method. ies
go to start
go to setting
go to connections
in this go to connections
go to gprs setting
go to Add a new modem connection
go to General Enter a name for these setting as: BSNLGPRS Setting
Select a modem as :CELLULAR LINE (GPRS)
Next
Access point name: GPRSSOUTH.CELLONE.IN [as i am tamilnadu bsnl south zone]
Next
User name: YOUR CELLONE NO 94**********
Password: YOUR CELLONE NO 94**********
Finish
go to Proxy setting
select [tick] This network connects to internet
select [tick] This network uses a proxy server to connect to the Internet
then go to Connection Setup
Select Operator
Country: India
Operator : BSNL
then OK
Do you want to continue?
Yes
finally RESTART YOUR DIVCE
say YES.
Afer restart you can now use bsnl gprs.You have note a symbol at top of your htc mobile as E or G.
If you have problem to connect bsnlgprs With this correct setting call cellone customer care about this or call me
For BSNL South prepaid or post paid use following settings:
Start/ Settings/ Connections /GPRS
Connects to : Internet Access point: gprssouth.cellone.in
Leave other items blank.
Start/ Settings/ Connections /Proxy
Donot creat any proxy
You donot require any thing else. GPRS will work on your mobile and also in Internet share. Internet share works with cable and bluetooth. Browse on mobile or laptop !!! 9448834529
