My phone keeps asking for the pass code when I enter "0000" I get the message unable to pair with vbt 2050.
Hold the volume up (+) button down along with the call button for 5-10 seconds (until the led lis solid). Then, while the led is lit up, initiate the pairing on your phone. It should pair this time. It worked for my phone, which was having the same problem you described.
25cents solution worked for me too.
EUREKA AT LEAST I FOUND THE SOLUTION PAIRING VBT2050.
THE STEPS ARE ALL RIGTH BUT YOU NEED HOLD ANSWER BUTTON WHILE YOU ARE ENTERING 0000 PASSCODE AND DONT STOP TO HOLD IT STILL YOUR HANDSET ASK IF YOU WANT CONNECT VBT2050. YOU WILL SEE THE LIGHT ON FIRM OF HAND SET WHILE HOLDING.
I REPEAT WHEN YOUR HANDSET WAS ON DONT STOP HOLDING ANSWER BUTTON STILL YOU FINISHED ALL STEPS
Pairing Nokia E71 with Jabra BT2010
I pressed the button with the on/off button and that did not help but then I held down the on/off button until the led was solid and then my Nokia E71 paired. (by going to bluetooth and scrolling right and selecting pair with new device).
Prior to pressing the and on/off button I had tried to just hold down the on/off to get a solid LED but it would not go solid, after the on/off and pressing, just pressing the on/off for 10-20 seconds finally got the LED to go solid and I was able to pair my Jabra headset with the Nokia.
Thanks for all this help
Try resetting it. "It is possible to reset and test the headset. Make sure that the headset is powered off. Press and hold the answer/end button and the on/off button at the same time for 10 seconds. The headset will automatically turn off after approx. 10 seconds. The next time you power on, the headset will go into pairing mode as the first time you powered your new BT2050 on."
Quoted from:http://www.rtbtechnology.com/document/bt2050_UM.pdf
I have the same problem, but with the blackberry curve. I was able to pair it once, then I had to unpair it so my husband could use it with his phone and when I got it back it wont pair. It says "unable to pair Jabra VBT 2050" it wont pair with his phone either.
First time it paired fine, but I forgot to rename my phone. I deleted the jabra, gave my phone a unique name and tried to pair again, but I got the same error message as mentioned above.
Problem pairing my jabra BT2010 with my Nokia E71 phone and kept on asking passcode and i tried input the default nos "0000" but the paasword in unable to pair with my unit. Please help me to solve my problem....
25cents - you are awesome, very helpful to my curve, hope it helped everyone else!
problem with pairing my jabra vbt with my blackberry storm
I am facing the same problem
