Isar M30100 installion manual available FREE from :http://www.idealheating.com/product-lite...Isar M30100 installion manual available FREE from : http://www.idealheating.com/product-literature/dicontinued
You can't post conmments that contain an email address.
All the combis I've come across merely fail to fire if the pressure is not up. not only do they not fire, nothing else works including the pump and in any event the pump should not overheat just on low pressure. water loss - try turning off the valves on the flow & return pipes [3/4 inch ones] 1 valve per pipe . This will isolate the rest of the system - rads etc Note pressure over a time period. In this mode the hot water circuit will still work but do NOT use the heating circuit 1/2 bar over 2 days is not serious but it should be found Once you have either mended the leak in the rest of the system or found there is not one, insist on a replacement boiler In any event having looked at the reasons given for the fuse blowing, I would definitely get a replacement. These problems should not happen on a new boiler I list Worcester.-Ariston-GlowWorm-Ideal- and many others who would confirm this
if the timer is built into the boiler there is a small switch on the right hand side. this can be moved up and down to bring the timer on and off.
if you log onto the ideal web site you should be able to download a copy of the programing instructions.
TAKE A SHPO VAC AND CLEAN AREA. MAKE SURE YOU PAY SPECIAL ATT. TO THE PILOT LIGHT. FIND BUTTON HOLD IN AND IGNITE DONT LET GO WHEN IT LIGHTS FOR AT LEAST FIFTEEN SEC.. YOU MIGHT ALSO HAVE TO TURN THE THERMASTAT OR KNOB TO PILOT FIRST. AFTER IT HAS LIT TURN UP FLAME
I'm Harvey, the master plumber. You asked where you can download instructions/user manual/installation guide for
Ideal Mexico CF60P Water Heaters. I believe this is the correct link:
http://www.chspares.com/partselect.php?test=121
Some Companies will e-mail it, others will respond if you call them on the phone and they will fax it or mail it. Contact info on the link that you requested form me. I'm happy to help you! Feel free to contact me.
