Does not spin as rapidly as it used to. Clothes of course do not lose water at cycle's end. Either motor, maybe brushes, or transmission, but I know nothing about that, or, there is a printed circuit controller housed in the upper portion. Any troubleshooting suggestions?
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
SOURCE: my maytag neptune front load washer won't spin all the water out
does the door lock light still come on, ???place in a spin cycle to check, if need be( it will take a min or so to light), if hte light never comes on i would remove three phillips screws from across teh top of machine console, there will be a circuit board mounted to the back wall, slightly left of center of the board youll find a light blue box,tiny maybe 1/2inch rectangle. interested in the resistor directly above that box, is theres abig burn mark around it??? if so there is your problem , youll need to replace the machine control board and also the wax motor in hte latch assembly( do not change one with out the other
SOURCE: I have a Maytag MAV6300AWW,
The plastic pulley is worn out typically at the bottom- most common issue. It needs to be replaced. Thanks, please leave feedback or contact me again for more info if you need it.
SOURCE: wet clothes after spin cycle
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
SOURCE: LAT9604AAE No agitation but drum spins and drains water
cold possibly be just the agaitor but odds are u need a transmisson not worth repair
