I want to copy content of dvc to dvd. to do this i require a dv cable with 4 pin input jack to fit toshiba dvr at one end and a jack to fit canon fs100 at other. the camera has 2 output sockets-one for connection to tv ,( single pin ) and one for connection to computor (mini usb ) from where can i purchase such a cable?
SOURCE: Panasonic NV-GS15 Mini DV Digital
U get usb cable and a software cd with ur cam.Install the software and attach ur cam to pc with the help of USB cable and get ur movies copied from cam to pc
SOURCE: Canon ZR800 won't connect
Your saying 4 pin USB firewire. Which one is it?
It should be 4 pin firewire.
What is the error message that you are getting?
SOURCE: Unable to use firewire Sony handycam DCR-HC 54E (mini DV)
I have a Sony Camcorder DCR-HC62E with same problem and found a workaround. The iLink seems not to be enabled in the camcorder except for only one of the working modes: setting PLAY/EDIT and then choosing STREAM. Once you get to this condition with the provided USB cable properly plugged at both ends, Windows recognizes a new device and asks for a driver, so you insert the provided Handicam Application Software disk and make Windows install it (I got a Windows message saying the driver is not safe but went on anyway).
Of course that in such a mode the Sony application "Import from Handycam (tape)" cannot and does not work, but using Microsoft Movie Maker and selecting File->Capture Video the camcorder is shown. Select it by clicking its icon and Next. On next screen Captured Video File define the required info and press Next. On next screen Video Setting select Best Quality.. and Next. On Captured Video screen be sure to have checked Create clips when wizzard finishes and proceed manually as follows: go to the beginning of the tape (or of the part you want to download) using the rewind/forward/play/stop controls in the camera. Once ready press Start Capture in Movie Maker and simultaneously Play in the camera, the filemed movie will show in the preview as it is played. When you're done stop camera play and press Stop Capture.
SOURCE: Required USB Driver for mini dv Panasonic NV gs 15
The Panasonic NV gs 15 can only be used as a webcam with the USB cable.
You need a 1394 firewire / DV cable to transfer the video to your pc.
SOURCE: My Panasonic NV-DA1 Mini DV will not conntect to my PC, TV, or DVD recorder
I purchased a pluscom easy cap usb2.0 capture device,it comes with disc.Load onto your Laptop or Computer put in your number from disc cover and it will download a program that says VHS to DVD.Its all you need. connect your camera lead from the av out in side of camera it should have a red,white,and yellow plug on and connect it to your easy cap usb plug in then just push capture and your downloading. you have to have a play to select what files you want to save to but its easy enough. Its only taken me about 2 yrs to solve this download problem but all ok now.Good luck.
Anywhere that sells them - try Maplins
