Super Glue is a cyanoacrylate adhesive. It's impervious to water, but can be dissolved with an organic solvent, such as acetone. Some nail polish removers contain acetone, but be sure to check the label, since many acetone-free products are available and will not work against Super Glue. It's also possible to find pure acetone in stores that sell home supplies or art supplies, because acetone is a useful solvent.
remove as much of the dash as you can and find the wires that pull and push the flaps and lubricate them, use white lithium grease spray to get into hard to reach areas. use it liberally. glue the knob with some really strong glue like gorilla glue or any super glue or replace the part. remove the heater core valve that controls the flow and remove buildup or dunk it in CLR or rust remover, lubricate and place it back in.
Most likely the knob itself just broke. You would do better to replace the knob than glue it because if you glued it and ever had to replace the timer then you might cause more damage getting the knob back off.
at auto store they sell gasket adhesive or use a little silicon and clean cover til oiless ( use break cleaner) and glue gaskets in place and let dry and then install
Plug the glue gun into an electrical outlet. Make sure it is placed in a secure place, away from flammable items. As the glue gun heats up, a little bit of glue might drip from the end so you won’t want to leave it on a wood table or on carpet. Insert a glue stick into the back of the glue gun. If the glue gun already has a glue stick in the chamber, keep a second one in reserve nearby. Gather the materials you want to glue together. Hot glue works exceptionally well on thick fabrics, dried flowers, Styrofoam, wood and plastics. Since it leaves a thicker residue, it is not the best choice for thin papers, fabrics and ceramics. Check to see if the glue in the gun has melted by squeezing the trigger slightly and touching the tip to a test piece of paper. If the glue comes out easily, the glue gun has heated up fully. If the trigger is hard to pull, wait a minute more for the gun to heat more completely. Pick up the glue gun and squeeze the trigger slightly while you draw a thin line on one side of the item to be glued. Immediately place the other object to be glued on the glue line, pressing firmly. Hold the two pieces together for about 15 seconds. Test to see if the item still holds when you remove one hand. Let the item set for a few minutes in order to “cure.” Once the glue has dried fully, use a fingernail to scrape away any of the excess glue.
