I have reset default bios settings in the setup and now no signal on monitor. Machine doesn't boot up at all. Have disconnecting hard drives plus cmos battery but still no luck. Keyboard doesn't come on as well. Please help??
SOURCE: PC was booting to HP screen with constant beep.
If the computer is not reaching the BIOS screen one of the components is most likely faulty. I strongly suspect that it is either the Motherboard or the CPU. If you have made sure the CPU is seated correctly you may need to try alternate motherboards or try the CPU in an alternate computer/Visa-Versa. Hope this helps you troubleshoot and good luck.
SOURCE: Screen displays no signal and then shuts off.
try a new power supply if still same result change the motherboard sorry thanks and good luck
SOURCE: Problem replacing sata drive with eide drive in HP A1330n
if hard drive show in the bios setting and not loading the window then your hard drive not work properly.change your hard drive.
SOURCE: HP a1250Ncomputer wont boot up.
OK, ONE DVD MUST be set as MASTER and ONE as SLAVE. The master MUST be on the "End" of the cable, the SLAVE, on the other. First try with ONE drive, and if you get it working, swap them out too at first, then after establishing that it works OK with just One, the MASTER, then introduce the SLAVE. Do Not forget to RE-JUMPER between swap outs.
SOURCE: HP Pavilion Slimline s3120n. turn the computer on
Try the display on a different PC. The on board video may be defective, if so you will need to buy a new video card. Check to see what type you need. Good luck. I hope this helps...Have a good day.
Make sure the battery has plenty charge or remove the battery for a while, about 5 minutes to see if that restores it some motherboards cmos batteries are soldered in
You could check the site for the machine vendor to see if there is a reset jumper.
If that doesn't work then you will need to refresh the BIOS
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values hopefully against a recent
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS.
To do that you need to press a key while the computer is booting Usually the Delete or F2 but can be other keys
It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one.
You will also need to reset the time and date.
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
Press F10 Save, Exit and re-boot and everything should then work
hope this helps
hope this helps
