SOURCE: 2001 Honda Odyssey Transmission Problem
call American Honda, there was a recall on 2001 Odyssey transmission and therefore Honda has an extended warranty for transmission. i just had mine replaced at no cost.
SOURCE: 2001 Honda Civic Timing Belt
It is not an eays job. I would have it done by a tecknician so you have a warranty. The honda dealer is your best bet because you will oem parts and the job will be done right . then you are good for another 90,000 miles. I hope this helps. Don't forget to rate my answer.
SOURCE: 2002 Honda civic makes rear end noise when going around corners.
well, differential repair can be costly but, the dealership will cost the most to be honest. about around $1200 at the least.
SOURCE: 1999 honda odyssey-engine stalls while driving-electric is fine-
Maybe the solution
There is a recall on the ignition switch,
My 99 Ody with 120K would suddenly switch off and come back while runing, Take it to dealer and report to Honda, Since out of warranty. The dealer would do the repairs estimated at $100 charge to you.
