Precor Error 05, Key Depressed at Power Up
Probable Cause
1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
Precor Error Code 05
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
SOURCE: treadmill precor 655 runs suddenly fast then
speed sensor error
check clean or replace
Testimonial: "easy was it it was good after i tighten the screws of speed sensor"
SOURCE: The belt on my Precor
Error 22 means the drive motor is diconnected. you will hear the fan and other parts make noise but check the red and black anderson connection between the main circuit board and motor.
SOURCE: 9.1.0 TREADMILL PRECOR PACE ERROR
Dear Sir:
Hello I hope everything is fine.
I will give some Tips:
Description
Errors 00 through Error 04 check upper PCA memory locations, RAM memory locations and
EEPROM checksum during the power up test sequence. If a fault is found during the power up
test sequence, the appropriate error code will be displayed.
Possible Causes
1. These errors messages almost always indicate an upper PCA problem when they are
consistently displayed. Failures causing these error messages to be displayed are rare.
Possible Remedies
1. If the error message is consistently displayed when the unit is powered up, the upper PCA
should be replaced. It is possible to see one of these messages displayed intermittently due
to external causes. If the units A.C. input significantly dips during the power up test sequence
the test could fail resulting in one of these messages being displayed. Treadmills operating
on non-dedicated A.C. circuits may see these messages displayed on an intermittent basis.
In other words, you need recalibration in your equipment, I recomend after you make a test for a RAM MEMORY.so contact your service call. I recomend Strong, INSTALL regulator Voltage is cheap about us$15,00 Radio Shak or another Electronic Place.
Thank you in advance , sincerely. Blessing.
If you need additional Help, please do not hesitate to contact me.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
