There is a large air bubble between the cartridges and the print head. How could I remove it? I tried looking around the web but could not find an answer. Thanks.
SOURCE: Epson CX4800 cannot clean the print heads
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
SOURCE: When I do a nozzel check the black ink on my Epson
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
SOURCE: epson sx210 inkjet printer trying
If you're using Windows,
XP :
Click Start, go to Control Panel > Printers and Faxes
Right click on your printer, click Printing Preferences, click Ink Cartridge Replacement.
Follow the instructions.
Vista :
Click Start, go to Control Panel > Hardware and Sound > Printers
7 :
Click Start, go to Control Panel > Hardware and Sound > Devices and Printers
SOURCE: keeps saying paper jamed when I try to print
On the Epson website it is confirmed that the Epson WorkForce 610 will not recognize transparency media. It is just the way the printer works; if it can see through the media, it doesn't think it's there.
However.....you can tape a sheet of white paper to the non-printable side of the transparency, and it prints just fine. I put two strips of scotch tape on either side, top and bottom. Works great. It's kind of a hassle, but better than not being able to print transparencies at all!
