Microwave Ovens Logo
Anonymous Posted on Mar 31, 2013
Turntable, oven light and fan suddenly stopped working
The turntable, oven light and fan suddenly stopped working. All other functions are just fine - microwave heats food, exhaust fan works, cook-top lights are OK . any suggestions are welcome. Thanks
  • Anonymous Apr 01, 2013
    thanks. mechanical or electronic switches? and how to locate and fix 'em?
  • Ron Ertwine Apr 02, 2013
    there electricl remove the cover there are a few two by the door and mybe 1 or 2 more they are very noticable can be checked with a meter
Ron Ertwine
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 113 Answers
  • Posted on Apr 01, 2013
Ron Ertwine
Expert
Level 2:
New Friend:
Cheetah:
Answers
113
Questions
16
Helped
17467
Points
170
You have a couple bad switches
5 Related Answers
Anonymous
  • 403 Answers
  • Posted on Feb 03, 2011
SOURCE: microwave just stopped cooking!
there could be two problems with your microwave. your diode could be bad or your magnetron is no good. Its definitely one of the 2. most likely the magnetron. if the microwave is more than 5 years old, and it is the magnetron i would suggest that you replace the microwave. if you would like instructions on how to change the magnetron or diode let me know and i'll walk you thru it. although i do recommend u let a professional take a look at it.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 11, 2006
SOURCE: LG 1925 Microwave suddenly stopped cooking, other functions work fine!
What you said about the the clock leads me to suggest that you first unplug it for a few minutes then plug it back in. It may just need a good reset. If you don't have your owner's manual you can download one here: http://www.lge.com/support/manual.jsp The mention of odor concerns me. It may just be a bit of food or grease on the waveguide cover, which is a small sheet or panel on the wall or ceiling of the cooking cavity, but it may indicate the failure of a part in the high voltage section. You may have an intermittent door switch. You can see some of my other responses for info on how to get our important text file that helps you diagnose and repair door switches and gives important safety tips.
Anonymous
  • 17 Answers
  • Posted on May 14, 2008
SOURCE: Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
Anonymous
  • 505 Answers
  • Posted on Jul 18, 2008
SOURCE: Danby Designer microwave (with exhaust
Its a bad magnetron
Anonymous
  • 319 Answers
  • Posted on Mar 21, 2009
SOURCE: Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Samsung microwave oven Model # SMH9151S. Turntable not turning fan inside (not the exhaust fan) is not working either.
It may be a failed relay on the control board, which I repair affordably.
See my profile picture if you need more help.
1helpful
It has power but is not heating anything
In order for a microwave oven to cook foods, its "engine" - the magnetron - must also be functioning. If the keypads, turntable, lights and all other functions are working but the food is not cooking, the magnetron has failed. Some local repair shops can provide a reasonable cost to replace, and it comes down to how old the oven is and is it worth repair or replacment.
2answers
Food still cold after cooking
Is this a combi oven? If it is not-and only a micro then there is no heating element. Try it on micro(if its a combi) with a mug of water for approx 30 seconds to test it. If its a combi-is the micro function still working?
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
SHARP R 88BKM no microwave
David
This is a sure sign that the MAGNATRON unit has went out on your oven and will need replaced! (This is what cooks the food!)
Please take a second and rate my response!
Thank You!
2helpful
Clock works, timer works-but turntable and other functions stoppe
you have a bad control board . this board had 2 relays one for the magntron and one for the turntable and the cooling fan together . when the turntable goes out so does the cooling fanm and the microwave overheats ...... there is no good fix for this , the control will cost more than a new microwave . please do not use with this happening . i have see them start on fire when it overheats . please be carefull good luck
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
