Furuno navigator gp32 has waas &gp31 has no wass capability so what has the gp30 not got
SOURCE: Furuno GP31 - PC wiring instructions
try
http://furuno.inforce.dk/graphics/14_Softwares/09_gps/FURUNO_GP-32_pc_connect.pdf
SOURCE: can we connct furuno gp31 to pc
Hello!
Yes, the GP31 can connect to a PC. With the wiring harness, it has an RS-232 port, which allows it to connect to most PCs, laptops, and even most palmtop systems.
Hope this helps you out,
Ken
SOURCE: LCD furuno GP31
Even Im facing the same problem, when I gave it for repairs, they says that the screen is moulded with Body, hence it cannot be repaired.
SOURCE: wiring
use the yellow and green check for pulsing voltage on wires with digital meter measuring 12V you must turn on the data in the Furuno menus
SOURCE: What do I do to download my GPS Furuno GP31 to my
Go to www.furunousa.com and download the installation manual
I have posted the Operator Manual at
http://www.offscotland.plus.com/Temp/GP30-GP35-Operator's_Manual.pdf
Use this to check out section 7-10 to make up a cable to connect to a PC to allow download of data. Then, using the manual as a reference figure out the sequence of buttons to press to get the GP31 to download the waypoint and route data to the PC. Just press the buttons and assume the display is showing the next prompt. If you know someone you has a working GP31 get them to do the sequence and write down the buttons they press. You just copy the same sequence. You will need some software on the PC to capture the data,
Is this a request for a GP31 Manual? I have posted
http://www.offscotland.plus.com/Temp/GP30-GP35-Operator's_Manual.pdf which is basically the same beast.
http://www.offscotland.plus.com/Temp/GP30-GP35-Operator's_Manual.pdf The GP30/GP31/GP32/GP35 are all similar.
