Just installed the head unit today, when I turn the power on in the car the unit powers up for about 3 seconds then shuts back down. No display, no sound but if I hit he eject button the LCD will come out with no picture. I've checked the fuses, I tried resetting the unit, and there is no change.
SOURCE: Power Acoustik PTID-4005 BYPASS BRAKE
Just ground you brake wire directly to the metal frame. It should work fine. Goodluck.
SOURCE: kenwood kvt 911 dvd head unit
I have a question. Everything is working perfectly except for there is no picture on the TV nor DVD. It was working fine until the other day when I messed around with some wires seeing if any of them were loose. Any suggestions?
SOURCE: Have one wire for audio sub out, but two input ports to amp
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
SOURCE: help i need a wire harness for power Acoustic dvd player
you would have to order it from poweracoustik.com. go to poweracoustik.com then go to contact and there will be a number call it an order.
SOURCE: bypass having to use the parking brake on power acoustik ptid7250
no, you can't, because watching a video while you drive is an insanely stupid thing to do.
