In order to do that:
1. Go to Settings
2. Choose the option More Networks in the Connection settings.
3. Then tap on Mobile Networks
4. Find the Network mode.
5. Change the Network from 3G to 2G.
A much cheaper solution is to by a 3G/GMS antenna. It is usually quite small and you can put it anywhere in the room. Remember that the higher the antenna is located, the better the signal is. If you need an antenna for a bigger building we would recommend hiring a company which specializes in that field.
you have to set it up manually. get info from your service provider, check if their 3g band matches your phone 3g band. if they dont match you will be on 2g/edge speed. google out internet and mms settings for your service provider. after you get that info go to settings-->wireless&networks-->mobile networks-->access point names-->option-new apn-->type in the info in the appropriate field-->save and you should be good to go.
First Option: Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So Secend Option: Your Phone Network IC Fault So Please change Network IC And Network Signal Problem will Solved if it is there isn't much you can do on this side of the network. Contact your phone company.
This usually indicates that your Mobile phone provider does not have a network coverage in your area (note: in Country areas, limited network coverage is usually from Vodafone, 3 or Optus). To be on the safe side, make sure that you allow both 2G and 3G network access as 3G access is usually limited to larger cities/towns.
Check with your Mobile phone provider for both 2G and 3G coverage in your area.
Emergency calls are allowed from any Network even if your provider does not service a specific area.
if u r in Indian then follow the given steps by me
SAMSUNG BSNL 2G AND 3G NET SETTINGS Listen friends, i know how to connect internet from Samsung s5603, s5350 and many more____ Just follow my simple steps happily--------
Operations to be done in Samsung mobile: 1-
Go to MENU > SETTINGS > APPLICATION SETTINGS >
BROWSER PROFILE > create > write BSNL 3G in place of
connection o1 > write bsnlnet in access name > save it and
set it as default.
Operations to be done in computer: 1- Join your mobile with your computer and run pc studio. 2- Click on widgets in pc studio and don?t touch your mobile as it may be angry. 3- Click on internet connection 4-
Click on add and complete following requirements connection
name.....................
BSNL 3G
COUNTRY..............................
other
Network
provider........................ other
APN
name..........................
bsnlnet
Phone
no........................ *99**1*1# 5- Click ok. 6- Click yes.
----------A small help to you from -------------aditya dixit, India------email id: [email protected]
