Sony Ericsson MT11i Xperia neo V Unlocked Red Logo
Nancy Rick Posted on Mar 31, 2013
My xperia keep restarting..
When i switch on my phone, it's keep restarting and never reach home. can this be fix?please help me
3 Related Answers
SALMAN NASEER
  • 1011 Answers
  • Posted on Apr 16, 2009
SOURCE: Restart
dear,
did u do a factory reset or master reset with it...
if not try it by the way....
Anonymous
  • 496 Answers
  • Posted on Feb 06, 2011
SOURCE: My Xperia X10 keeps on
DEAR FRIEND, YOU WILL HAVE TO RELOAD YOUR PHONE WITH A FLASH FILE.
Anonymous
  • Posted on Sep 13, 2011
SOURCE: my xperia x10 with android
I also have an xperia x10 with the same problem - i've updated from 1.6 to 2.1 with no issues back when 2.1 first came available. Now updating to 2.3 causes the same symptoms as the origonal poster.
Any help would be great
1helpful
My sony xperia is not turning on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
2answers
I can't make or recieve phone calls on my xperia ray
Make sure your Audio Settings are correct. I am not sure if you can turn off your Built-In Speaker and Microphone. Also, make sure you have nothing plugged into the Headphone Jack.
Else, try updating your Phone Software to the latest version, available here:
http://www.sonyericsson.com/update/?lc=en&cc=gb
Select Xperia X10 from the list and download the software update.
You must plug your Xperia X10 into your PC using a USB cable to perform the update.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
2helpful
My xperia x10 with android 2.3.3 freezes and thenkeeps on restarting for itself. i have flahed it twice but it's not solving the problem.. please...please..please help me.....
2helpful
My sony ericsson xperia x10 was restart it self and loss internet connection
resetting to factory settings your phone may fixed the problem but please be aware that all your recently data or contacts may be delete.
How long is the battery life?
As far as I discover ,up to now, the battery life of the Sony Ericsson Xperia X10 smartphone has been kept under wraps. The official product page is just left blank under the battery performance section. However, with the news of the handset launching in Japan, the official SE Japan site does reveal this juicy information. Given its 1GHz Snapdragon chipset and 4-inch screen, I wasn't putting too much hope in decent battery life, but it's looking reasonably okay.
Talktime with 3G networks should last for 4 hours and 50 minutes, whilst a 3G standby time of 200 hours is quoted. Obviously official numbers are always inflated, but at least you'll hopefully be able to get a good days use out of it before having to re-charge.
Just for your own test;
On the dialler press * #*#4636#*# * and under battery history make sure that your phone is sleeping when you are not using it. (Time spent not sleeping)
If its at 100% then an app you've installed is preventing your phone from sleeping. I think the latest firmware fixes the issue
Please switched off the auto screen brightness and set it manually at about 75% which should shorten the battery life but so far no.
A free program called TaskKiller will definetely help to close the .apps draining battery...
Pls read the articles on the URL below for more info and Tips..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
How To Fix The Battery Life On The Sony Ericsson XPERIA X10
http://www.sonyinsider.com/2010/04/13/how-to-fix-the-battery-life-on-the-sony-ericsson-xperia-x10/
1helpful
Hi! I need to unlock my sony ericsson xperia x8 phone from telering network in austria. my IMEI is 012560003752507. Can you please help me? I went to all mobile stores and nobody can't do it. Thank...
It's Telstra Network lock in Australia!! You need to Unlock it using the Unlock code,You can get the code from superunlockcodes and get the Free Unlocking Instructions from here Mobileunlockguide and Unlock it step by step...
Sony Ericsson Xperia X8 Unlocking Instructions Warning: Do not enter any wrong unlock unlock codes on your Sony Ericsson Xperia X8 mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your Sony Ericsson Xperia X8 with a Not Allowed SIM Card.
2. Your Sony Ericsson Xperia X8 will request to enter an unlock code.
3. Tap the box where you have to input the code and a number pad will appear.
4. Type in the unlock code we send to you.
5. Press the 'Unlock' button on the phone.
6. Your Sony Ericsson Xperia X8 phone should now be unlocked.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Sony Ericsson Xperia X8 is locked to.
Jun 23, 2011 • Cell Phones
1helpful
Exist free unlock xperia mini pro? if it does where can I get it?? Thanks for your attention
Free Unlock code no one provide,also not possible to get..it' latest Model Mobile so that You need to use the paid Unlock code,to get the code reach the Online sites,get the code at Superunlockcodes and Unlock it.....Find which country Network it locked now!!!
Sony Ericsson Xperia X10 mini pro Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Sony Ericsson Xperia X10 mini pro mobile phones. If you enter over a certain amount of wrong unlock codes on your Sony Ericsson Xperia X10 mini pro mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your Sony Ericsson Xperia X10 mini pro with a Not Allowed SIM Card.
2. Your Sony Ericsson Xperia X10 mini pro will request to enter an unlock code.
6. Your Sony Ericsson Xperia X10 mini pro phone should now be unlocked.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Sony Ericsson Xperia X10 mini pro is locked to.
Each Sony Ericsson Xperia X10 mini pro mobile phone has an unique unlock code. You can buy the unique unlock code for your Sony Ericsson Xperia X10 mini pro mobile phone using the form above.
2helpful
5helpful
2answers
Internet settings for my sony ericsson xperia x 10 mini
sir please call to the related simcard customer care and say the cellphone model number.and the phonenumber then they will send the gprs settings to your cellphone save the settings and switch off your cellphone and again switch on. then the cellphone connect to the internet...........
Top Sony Ericsson Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Sony Ericsson Audio Player and Recorder Expert? Answer questions, earn points and help others
