Hi, i have tried connecting my JVC Everio GZ-MG130 Camcorder to my dell laptop which has windows vista home premium installed but after repeated attempts i have failed to make any headway. it recognizes the camcorder but is unable to find and driver for it, while the everio site says vista has the driver inbuilt. plz help
None of these solutions work.
I have a mouse that works fine in one port, but is "Unknown Device" in the other ports. I try to tell Windows that it uses the same drivers and it just refuses to accept it. (gives error sound when I try to click "ok" on find driver.)
I'm told this is a common error with Vista, but of course, the MS site basically says, "your devices suck" instead of recognizing the errors of its own system.
Have you tried installing the supplied software the Setup/Install program in Administrator Mode, with Compatibility Mode set for XP? Install the software like this and AFTER you install it THEN plug in the camera, if it asks for drivers.. let it search the computer point or it to the CD.. Hope this was of some help.
You have trojans!
SOURCE: JVC Everio GZ-MG130 can use as webcam?
There is a program i heard of halled trackercam but for somereason it doesnt work with my jvc, im not sure why.
SOURCE: I've bought JVC Everio GZ-MG130 Camcorder, and
Try http://www.pricecomparehelp.com/page/3345.html
They appear to have a free download for the driver you want
Thank you Silverdragon for the solution.
Here i would also like to add that my issue with vista was more of usb related rather than being JVC specific. almost all my usb devices failed.
To correct the JVC and all other usb related issues you need to delete the inf files from folder c:/windows/inf and restart the computer
a detailed explanation is given at the link provided below http://forums.logitech.com/logitech/boar...
once the computer is restarted connect the JVC camcorder to the system, windows will start searching and will ask you for the driver location. select the location as c:/windows and the driver will get installed. If you get a message saying windows cannot verify the manufacturer select install anyway and it will get installed.
can not cunt to vista
which files do i delete ? from the inf folder to fix problem
