Question about Bosch WFK 2401
My bosch wfk2401 front loader is stuck on spin
My bosch wfk2401 front loader is stuck on spin cycle and wont pump any water out
    Problem Solver:
  • 4 Answers
Hi
There is a door bottom right of the system which has a screw out (by hand) plug.
Remove this and ensure there are no foreign objects such as coins, bobby pins etc stuck.
I have found this to be a problem with the Bosch systems and cost me $150 the first time.
Ensure you have some towels as when you open the plug, water will escape
Mark
Posted on Jun 16, 2009
SOURCE:
Bosch front loader washing machine door not opening
The door will not open if the machine detects excess water in it. Run the drain or spin cycle to check if water is being expelled. If necessary check the pump filter for obstructions and the outlet hose for blockages. If this does not work you may have a problem with the pressure system, the door lock itself or a crack or break in the handle and it is not catching the lock mechanism, let me know if this helps or if you need further assistance.
Nov 24, 2011 | Bosch Washing Machines
I have a WFK2401 Bosch washing machine it is not spinning the clothes dry but the water drains from the machine. I did clean out the pump and trap but it is still not working. What do you think it is?
WFK2401 Bosch washing machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 21, 2011 | Bosch WFK 2401
Hello my name is Kevin Singh and i had purchased one of your Bosch Front loading washing machines (model number: wfk2401) probably about 10 years ago i used it last on this last Sunday and it seems to not...
Have you checked the pump and filter are clear? Remove kickplate plinth panel to expose pump. Drain off excess water via small black hose. Check the hoses are clear, particularly if it is connected under the sink, via a spigot connection. If the machine has good motor action, but not spinning effectively, it will more than likely be a drainage problem.
Oct 19, 2010 | Bosch Washing Machines
Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Apr 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Something is stuck in our LG front loader washing machine so the water wont empty in the spin cycle
There should be two screws under the front lower panel. Remove the two screws and remove the lower panel. You should be able to access the pump from here.
Inscrew the cover on the front of the pump and clean.
Dec 31, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Water wont drain from my front loader bosch axxis washer and no spin cycle
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
May 05, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Water wont drain /wont spin out
  • assuming it is a top loader
  • it sounds like something is stuck in the water pump.
  •  if the water does not drain then it will never spin.
  •  take off the front panel (with a butter knife, push in the two metal clips in the front seam between the top panel and the front panel. this will release the front panel from the machine.
  • the water pump is located on the right side in the front.
  • before removing the hoses attached to the water pump get as much water out of the machine as possible so it does not spill on the floor.
  •  then take off the hoses and check inside the pump thoroughly; even a string might cause the pump to get stuck.
  • let me know if you need more help
Mike
Jul 02, 2008 | GE Washing Machines
When I use the spin only cycle on my Bosch WAE20260AU front loader it runs the pump for most of the cycle time. It only spins briefly mid cycle and the clothes are still very wet at the end. I do a lot of...
I have the same problem on a Miele W418 washing machine.
Just will not spin at all although the Pump out motor and the rest of the washing cycle all appear to be working.
Jun 15, 2008 | Bosch Washing Machines
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
382 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
