Dishwashers Logo
Posted on Mar 04, 2009
I have a GE Evolution Quiet Power Plus dishwasher its in very good condition but after a wash cycle it leaves about 2 inches of water in the bottom of the unit,this just started about a week ago,ideas on a fix appreciated.
  • 2 more comments
  • Anonymous Apr 05, 2009
    same as, after wash cycle there is 2 inches of water left. waht can I check to slove this
  • Anonymous Apr 06, 2009
    Idem for me, 2 inch
  • Anonymous Apr 16, 2009
    same. won't drain completely.
  • geojay May 06, 2009
    Ge Quiet power Diswasher problem . I have the same problem with the water left in bottom after the cycle is complete. If i move the timer to the pump location it empties ok . i suspect the timer.
Panisse
Level 1:
  • Contributor 2 Answers
  • Posted on Jun 04, 2009
Panisse
Contributor
Level 1:
Answers
Questions
0
Helped
1960
Points
5
A serviceman just solved the problem in 10 minutes. It is the valve inside the dishwater at the back. It got worn after five years. Cost me 8$ plus the call.
My GE quiet power 2 dishwasher isn't cleaning
its your water actually. go to www.dishwasherfilter.com and get the dishwasher filtration system. it filters the hard minerals that leave spots and film on dishes before they enter your dishwasher. you will love this product.
Apr 25, 2013 • Dishwashers
2helpful
Dish washer \does not rinse good leaves white flim
Hi:
Some things you can do to try to improve your dishwasher's performance:
1) Make sure your dishwasher rinse agent dispenser has rinse agent in it. The filler is usually close to where you put soap in the dishwasher.,
2) Consider switching brands of dishwasher detergent, if you are experiencing problems. Depending on the water condition in your area, certain brands work better than others. Ask your neighbors what works well for them.
3) try different wash cycle's with your dishwasher. Sometimes the economy cycle doesn't work as well as it should.
Same problem. 2-3 inches of water left in the dishwasher at end.
Inspect for plugged drain screen. Sometimes you have to take apart the bottom area for access...
2answers
Dibris on glasses afterwash. Dishes not coming clean
First check salt level is ok, the next thing may be it's having problems pumping out after the primary wash.
Try running a hot cycle with a dishwasher cleaner or 2 cups of washing soda, then pull out outlet hose and check it's clear.
Check all filters are clear and in good condition with no cracks.
Water keeps coming back into dishwasher after cycle is done
sounds like maybe one of your check valve is not working right.
Jun 03, 2009 • Dishwashers
2answers
I have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. I can manually hit the start button twice and it will go...
Hi jeffwirch,
I'm Harvey the Master Plumber.
Your problem is: You have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. You can manually hit the start button twice and it will go through a 2 minute cycle and pump out the water. You have cleaned the filter inside the dishwasher where it drains and have checked the hose to the disposal and it pumps out fine. It just doen't pump itself at the end of the cycle.
It sounds like a bad control board. It's in the top of the door panel. I don't recomend this repair to the average homeowner. You might consider the Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
20helpful
6answers
Whirlpool Quiet Wash Plus Dishwasher is not despensing the detergent properly. After a wash cycle there is still some left.
My Whirlpool Quiet Wash plus dishwasher seems to have died. No power. None of the buttons work, it quiet mid-cycle. No breaker issue, my garbage disposal runs off same breaker and is working fine. Any ideas? I was thinking the comp. board that the buttons work off of is fried. If this is the case any idea how much to replace it? Would it be cheaper to buy a new dishwasher?
Apr 21, 2008 • Dishwashers
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
