What are the calibration settings?
SOURCE: 40" LCD Samsung LN-T4061FI've noticed my blues are green.
there is no calibration for this, what kind of problem are you having?
This sounds like a calibration issue.
Follow the instructions below to re-calibrate
Three readings are required:
· Empty: No media in the sensor.
· Gap (or Mark): Only the backing, notch, or reflective mark in the sensor.
· Paper: The label (with the liner attached) in the sensor.
To perform a Standard Calibration:
Step Operator Action Displayed Message Comment
1 (Media should be loaded and the appropriate Sensor Typeselected.)
2 Press the menu key.
Raise the printhead assembly.
MENU MODE
MEDIA SETTINGS
You are entering Menu Mode.
3 Press the enter key to enter
the Media Settings menu.
MEDIA SETTINGS
MEDIA TYPE
4 Press the FWD key and
scroll to 'Sensor Calibration'.
MEDIA SETTINGS
SENSOR CALIBRATION
5 Press the ENT key. SENSOR CALIBRATION
PERFORM CALIBRATION
You are beginning the standard
calibration procedure.
6 Press the ENT key.
Remove the media from the Media Sensor then press any key.
REMOVE LABEL STOCK
PRESS ANY KEY <yyy>
This sets the parameter for the
'empty' value.
Where 'yyy' is a numerical
value representing the current
sensor reading.
8 Position the label (and backing,
if any) under the Sensor Eye
Mark.
ã Note: If using preprinted
media, ensure the label area
under the sensor is free of
preprinted text, graphics or
borders.
Press any key to continue.
SCAN PAPER
PRESS ANY KEY <yyy>
'paper' value.
sensor reading.
The calibration was successful.
See note below if another
message was displayed.
10 Exit upon successful
calibration: Back out of the
menu tree by repeatedly
pressing the key.
If using gap or reflective media,
press and hold the FEED key.
The printer will begin
advancing media; allow at least
one label gap (or mark) to
advance under the sensor.
READY
