if possible please check your speed sensors within your generator to make sure each is still functioning properly. Otherwise, you might have to replace the sensors before the code goes away.
? 0:24
www.youtube.com/watch?v=CT9u64dZna0
Apr 28, 2012 - Uploaded by Jeremy vanEyk
Brand new Kohler Generator Test cycle issue. ... Oh, and Mike, good call on the carb--that happens on some 20RES models. ...Indicates Locked Rotor (Lr). ... I'm on my second 20 RES-L,home depot swapped out the 1st one. ... Kohler 20KW RESA Whole House Standby Electrical Generator - Duration: ...
The 12RESL has no user setup. That's part of lower cost on the DC 2200 controller versus an ADC 2100 or ADC-RES controller that came with the 12 / 17 / 18 RES models. Here is a link for the ADC 2100 Operation / Installtion manual though. http://www.scribd.com/doc/60318571/Kohler-8-5-12RES-Install
No hay ningun manual en espanol para este motor CH730..segun su sitio web. Encontr? este manual en ingles..Por favor p?ngase en contacto por el servicio al cliente a ver si lo tienen en espanol (Kohler Engines).
http://www.kohlerengines.com/onlinecatalog/pdf/tp_2428_b.pdf
