Getting error code of f7 10.... Pls help!
The "F7 10" fault code implies the left front potentiometer/left front burner switch is open and will need to be replaced. Here is that part to order.
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
SOURCE: ES510 frigidaire range shows flashing F7 an 10 codes
Allowing it to dry with warm air and power off should fix it You can get an dust off can from photo store and blow some of the water out to speed things up could take 24-36 hrs depending on tempature.
SOURCE: F7 code and beeping
in version 1 of your model, F7 requires the replacement of the EDC (electronic door control)
in later versions F7 requires the replacement of the EOC (electronic oven control)
SOURCE: F1 fault code Frigidaire electric range
all solutions on the F1 show to replace the EOC control.
SOURCE: my frigidaire electric range had a f1 code come
The F1 code is a failure of the ERC (electronic range control), the only fix would be to replace the control board.
