SOURCE: FORGOT MY PASSWORD
when u start up ur computer u must inputting with F8 than safemode after u putting ur computer u can chance ur password
SOURCE: forgot password for my emachine computer
Boot your pc into safe mode, usually F10 as the pc power on, Go into the Control Panel, then users and you should be able to delete your account's password from the user's manauel.
Good Luck
C2Solutions
SOURCE: forgot password, need to reset
Try to get hold of a copy of Linux slackware and put it on to disk, adjust your computers boot option to boot from cd/dvd-rom. If you type in google reseting windows password using slackware there should be a walk through on how to do it, it is quite simple only a few command line commands and your done.
hope this helps.
OK, if you are running Windows 7, Microsoft tightened
security on it so you've got to have a password reset disk which 99% of the
people who own laptops with windows 7 fail to do. It should be one of the
first things you do when you buy the laptop. Otherwise, you're faced with
reinstalling the Operating System or possibly doing a System Recovery.
If you're on Windows XP or Vista try this:
Turn off the computer, then hit the power button to turn it back on and
immediately start hitting the F8 key repeatedly until you see the Safe Mode
option. Select SAFE MODE and let the computer boot up. When it gets
to the User Login screen it will show the Administrator userid and the userid
for which you forgot the password. Sign in as the Administrator (hopefully
you didn't put a password on it and forgot it too). Once the desktop
appears it will look different, the screen will be darker and the icons bigger,
but this is normal for safe mode.
Click Start/Control Panel/User Accounts
When the User Accounts screen opens, click on the userid for which you forgot
the password. Select the option to REMOVE PASSWORD.
Reboot your machine.
