To disconnect one of the jets to get more water flow to the other jets may not be very practical as you will need to remove the tub and cut the plumbing to the jet in question and cap it off. Rod Kidman We locate the "seemingly" impossible... Ph: 888-521-6183 Fax: 801-417-8027
The other solution that you may use is you have adjustable jets is to turn the water off by the face of the jet, clockwise.
If your jets are not adjustable then the first solution would be your only option other than purchasing a large horse power bath pump so you would get more water flow.
SOURCE: Bathtub jacuzzi (motor turns runs but nothing coming from jets)
Each Jet will have an adjustment many times right on the jet nozzle. Carefully try to rotate them counter clockwise to open up the jet. This assumes you can here the motor running.
Phil
SOURCE: Only 3 of 6 jets in jacuzzi tub working
Make sure the jets themselves are fully opened. Some models you can turn individual jets on & off
SOURCE: jacuzzi tub makes noise but jets wont work
sounds like maybe the impeller is just spinning on the shaft of the motor.
SOURCE: i have a leaking jet in a pearl jet tub. it's an
one of the quick ways to fix leaks at jets is by using Millaput two putty resins mixed and worked round the outside of the defective jet hope this helps
SOURCE: Jacuzzi jets smell like rotten eggs when turned on.
Any time you get a strong smell of rotten eggs it is due to a high concentration of sulfer in the water. Are you on well water? I would suggest using a cleaner like http://www.sani-bath.com/ to clean out your system.
Testimonial: "Thank you so much....I didn't even know that had products like these. I am ordering as I type. By the way, we don't use a well, but I'm sure it will"
