Question about Compaq Computers & Internet
Compaq sr1902uk network adapter driver
Looked on the HP website; the drivers there did not work. I now have the solution. I used SIW (System Information for Windows). This told me that my SR1209UK had a Gigabyte 8IG1000MK motherboard. Drivers downloaded from Gigabyte worked a treat. Hope this helps someone.
  • Compaq Master
  • 4,305 Answers
Thanks but............. and is and Obsolete PC. at HP and MS.
sr1902uk (England?)
  1. what OS? drivers match a OS, XP?
  2. sure some makers of mobo offer drivers that HP ended. sure.
  3. so does the unstated NIC chip maker offer drivers but not for all OS in most cases.
  4. The best way to work on old PC is run the PCI scanner(ask)
  5. identify the chip maker and model (ven=x dev=z)
  6. then we can get any driver, for any OS if the chip maker has one, and many dont. for newer OS. (and ther reverse)
  7. Finding drivers for old PC is not easy, (for me sure) but for most, it's very hard and the risk of getting virus high.!!
  8. ask how to do it, using the scanner , lacking HP support.
Posted on Feb 23, 2018
SOURCE:
viaujoc
  • 60 Answers
SOURCE: Ethernet Drivers for Compaq Evo for XP
The Compaq EVO D510 has an onboard Intel PRO network card.
You may download the latest driver directly from Intel's web site:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldId=4275
Posted on Apr 18, 2008
SOURCE: Rtl 8139D drivers for Red Hat 5 enterprise edition
I am using P-IV intel based motherboard having linux operating system installed , This is RHEL5 version . I have network adapter of RTL 8139D. Kindly suggest me the suitable drivers to download.
Posted on May 30, 2008
SOURCE: i need network driver for my compaq pressario v3228au laptop computer
how can i download jooyontech sound drive
Posted on Nov 09, 2008
SOURCE: Driver for Broadcom 802.11g Network Adapter #2
HI Gocha,
Try to get this driver from Intel website it might help you. Intel(R) PRO/Wireless 2200BG Network connection.
Regards,
K.Loges
Posted on Nov 30, 2008
I have no choice and open terminal then type “init 0′ (shutdown) :D. Then switch back to Windows XP to find the type of driver I need to install on Linux RHEL 5 and find solution over the internet. Noticed that I am using Realtek RTL8139/810x for NIC on Windows. After that, quickly go to the internet to find “how to install Realtek RTL8139/810x on Linux RHEL 5“. Then, I found that many crappy thing and **** suggestion over the forum. I read almost all Linux forum and follow all the sugesstion included to use ndiswrapper to install that Realtek NIC driver. But it doesn’t work on my machine. Yes I confess that I am new in this matter and perhaps ndiswrapper is too advanced for me.
Then, I have decided to try and error. I go to Realtek official website to see if I can get the specific driver for Linux. Found that:
RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L)
RTL8139C(L)+/RTL8139D(L)/RTL8100(L)
RTL8130/RTL8139B(L)
all at the same download page. Then I made I my own conclusion that, Realtek8100 or Realtek8101 can be use as well since I can’t find any RTL8139 driver for linux over the internet. Too not wasting your time to read my crappy story, then download this driver over HERE. DOWNLOAD DRIVER HERE, before that make sure you login as root. After download complete, just write the following command on your terminal:
[root@localhost ~]# cd Desktop (i put the file on Desktop)
[root@localhost Desktop]# tar xvvf r8101-1.001.00.tar.bz2
[root@localhost Desktop]# cd r8101-1.001.00
[root@localhost r8101-1.001.00]# make clean modules
[root@localhost r8101-1.001.00]# make install
[root@localhost r8101-1.001.00]# depmod -a
[root@localhost r8101-1.001.00]# insmod ./src/r8101.ko
[root@localhost r8101-1.001.00]# lsmod | grep r8101
r8101 28688 0 <—if this appear, then you’ve installed the driver successfully:)
Then check if your ip have configured correctly or not
[root@localhost r8101-1.001.00]# ifconfig -a
eth0 Link encap:Ethernet HWaddr 00:1C:25:4D:9A:0A
XXXXX XXXX MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
Interrupt:177 Base address:0×2000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:1611 errors:0 dropped:0 overruns:0 frame:0
TX packets:1611 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:4526976 (4.3 MiB) TX bytes:4526976 (4.3 MiB)
sit0 Link encap:IPv6-in-IPv4
NOARP MTU:1480 Metric:1
Since you can see the ethX which X is 0,1,2,3 (mine is eth0)…. instead of just lo and sit0, then its working now. NIC driver has been installed successfully.
Finally, on your terminal type:
[root@localhost ~]# system-config-network
You can see on hardware tab there are Realtek Semiconductor with status ok. Then, move to Devices tab, and click New > Ethernet connection > Forward > Choose REaltek Semiconductor…. > Forward > then up to you whether want to set DHCP or set static IP.
Now you can open Firefox or Konqueror and start browsing internet happily:)
[p/s] If check again on your terminal with ifconfig -a it should return your local ip address under the eth0 which is 192.168.1.* ; * is 2-255
Posted on Mar 07, 2009
Network driver and adapter for compaq presario SR5613WM
You can download the LAN and device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
www.compaq.com/country/cpq_support.html
Mar 20, 2012 | Compaq Network adapter
HP 530 wireless will not pick up any wireless networks. Please help
Hi.
First ensure that the wireless adapter is turned on.
If the adapter is on and does not detect any network, reinstall wireless network adapter drivers. the drivers can be obtained using the link below.
Download drivers and software
Reinstalling driver software usually fixes the problem, if it does not it usually means that the internal adapter is defective, in that case you will need to use an external wireless adapter (USB).
Sep 27, 2010 | HP 530 Notebook PC
I need to uninstall and then reinstall my microsoft network adapters because they are not working properly and i am not able to connect to the internet so i need to know where can i download the network...
Do not worry, to uninstall the driver, open device manager. under it choose network adapter and uninstall the Wired or Wireless drivers which you are supposed to.
Open HP.com
type the product number. EX: FZ017PA. (this is a Compaq CQ45 model). You will have something similar to it.
To locate the product number:
http://h10025.www1.hp.com/ewfrf/wc/document?tmp_renderType=findModel&lc=en&dlc=&cc=us&docname=c00033108&product=18703
Now, type the product number in the search area of HP.COM, choose your product and click support and drivers download. VOILA.!!!
regards
Jan 03, 2010 | Compaq Presario Notebook
I can't find network and video drivers for my HP Compaq nc6000 running with xp sp3. Please help me. I've tried all the drivers found in hp website, but none of them works. Do you know any other link where...
Download your driver from the link below
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=367369&prodTypeId=321957&prodSeriesId=367367&swLang=8&taskId=135&swEnvOID=1093
I am not sure what chipset you are using for your network card na dvideo adapter card.
If the download doesn't work,installed all the update including BIOS from the above link and check our again.Windows service pack 3 usually doesn't give problem on any other drivers installation except audio driver.
Dec 25, 2009 | HP Compaq nc6000 Notebook
HP pavilion network adapter not found
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model computer and the XP Windows version of the drivers you require and install them. Use this link to download the drivers :-
http://h18000.www1.hp.com/cpq-country/cpq_support.html
Aug 03, 2009 | HP Computers & Internet
Network problem in COMPAQ presario V3000
There are two ways to install the driver:
Install the driver using the wizard.
Forcely install the driver
Steps:
Right click on the icon that has the yellow mark
Click update driver
Choose install using specific location
Open the driver location
Then proceed to the Installation
Last restart the computer and check if you got still the yellow mark.
Note: Check the operating system and the adapter maybe there is a compatibility issue.
Mar 01, 2009 | Compaq Network adapter
Problem in driver notebook compaq with xp
try this driver.
http://www.belkin.com/support/article/?lid=en&pid=F8T003&aid=5239&scid=0
Aug 07, 2008 | Belkin F8T003 Bluetooth (F8T003V) Wireless...
Network adapter not showing up in device manager
The tech was incorrect - your network adapter is just not recognized by the system. If you install the correct drivers for your particular network adapter it should be recognized, which should then solve your problem. Search the Gateway website for network drivers for your particular desktop, and if the network adapter was added (not built into the computer) then determine the manufacturer and model of your network adapter, then search the manufacturer's website for the correct drivers.
Even easier, if you still have the original disks that came with your computer and/or network adapter, they should include the correct drivers.
Hope this helps!
Jun 07, 2008 | Gateway GT4024 PC Desktop
Internet connection
  1. Use a different computer and download the drivers from HP website.
  2. http://welcome.hp.com/country/us/en/support.html
  3. Download the network drivers. Download them all so you won't miss any your computer has.
  4. Reinstall using updated driver.
  5. If the driver does not come with an installer. Right click "My Computer" and select "Manage"
  6. In device manager right click network adapter or ethernet adapter and select "Update Driver" when asked for driver point the wizard to either the CD or USB drive you have the new drivers on.
  7. Not all drivers will work on your system but the ones that do will solve your problem.
Mar 05, 2008 | Compaq Evo N1020V Notebook
Internet driver problem
hi teclay,
in motherboard's cd, the net adapter drivers are included. it uses a Ethernet adapter and works perfectly.
to use the net adapter to a network, you'll need to configure that terminal in Network Connections (Start Menu) to LAN Connection. There you'll type the setting given by the network administrator, where the internet main server is connected (modem to line out).
Remember, the authorization to internet user must be given by the administrator too because of the modem-router, being in a network
complements.
Jan 26, 2008 | HP Compaq d220M (829160054797) PC Desktop
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
