You can download from this link: (click here). Open the link, click the blue link "Download this manual", enter the security code. Download will begin within seconds.
go to this site, it has an enlarged picture of your mobo and specs for it, you may be able to get the manual too. http://www.pcsandthings.com/k7s5a.htm
your welcome, Jeff
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=269&DetailName=New&DetailDesc=K7S5A%20Pro%20%20(V5.0)&CategoryID=1&MenuID=82&LanID=0 DOWNLOAD MANUAL N ALL DRIVERS HERE.i wouls suspect a jumper on the board is in the wrong configuration(place)RICHARDM69
Most common issue's for not being able to boot PC system.
1. Swap power cord/replace. Check video connection cable,
Check monitor power cable. (Check wall outlet is good).
2. Reset cmos/bios. (Need to use manual for board to reset)
3. (No display on monitor, can hear fan's running & LED's on case light/flash). Remove & re-seat video card, same for memory. (While in PC check all power connections & data cables to devices.
4. Fans not running & no LEDs do not light/flash. Power supply may be bad.
Go to this Asus site. Fill in the needed information on the right. This will than take you to your board. Download the manual.
Using the manual you will be able to set up your switches.
On the board and it is very hard to see. Every pin has a plus sign "+", that is the power. Black and some times white is ground. Other colors like red and green are "+". http://support.asus.com/download/download.aspx?SLanguage=en-us
The following link is the download page for Elitegroup Motherboards, just choose your motherboard in the side, i think it under Socket 462!!!
http://www.ecs.com.tw/ECSWebSite/Downloads/Category_Download.aspx?MenuID=6&LanID=9
hope this helps
regards,
babb
