Ganti prosesor dual cord
SOURCE: I need a free download of Integrated Intel Graphics Accelerator
This should be a link to your drivers. :)
HP/Compaq Intel Integrated Video Driver
SOURCE: don't reset password BIOS HP DC7100
If you cannot access the machine after if has been powered up, it is
still possible to get past the BIOS password. The BIOS password is
stored in CMOS memory that is maintained while the PC is powered off by
a small battery, which is attached to the motherboard.
Open the CPU casing locate the CMOS battery in motherboard and remove
this battery, all CMOS information (including the BIOS password) will
be lost. You will need to re-enter the correct CMOS setup information
to use the machine. The machines owner or user will most likely be
alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard,
making it difficult to remove. If this is the case, you have another
alternative. Somewhere on the motherboard you should find a jumper that
will clear the BIOS password. If you have the motherboard
documentation, you will know where that jumper is. If not, the jumper
may be labeled on the motherboard. If you are not fortunate enough for
either of these to be the case, you may be able to guess which jumper
is the correct jumper.
This jumper is usually standing alone near the
battery. If you cannot locate this jumper, you might short both of the
points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by
resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your
motherboard.
Many RTC's require an external battery. If your RTC is one of this
type, you can clear the BIOS password just by unsocketing the RTC and
reseating it. Good luck!
SOURCE: LOOKING FOR HP COMPAQ DC7100 SPF Ethernet
Go to this website:
HP Compaq dc7100 Minitower Drivers
Select your operating system.
You will then get a list of driver options. You will need to know what network interface you have to select the correct one.
Thanks for using Fixya.
SOURCE: hp compaq dc7100 video controller
http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/13032/eng/GFX_XP_MCE_2K_14.19.50.4497_PV.ZIP&lang=eng&Dwnldid=13032
SOURCE: 917-Front Audio Not Connected Problem with
Please connect front audio cable with motherboard in the a audio port of motherboard.If we work with sound card then connect front audio cable with sound card.
