I have an Amana s26ide by side, the fridge temp light keeps flashing, I have to put the temp at level 9 to keep the fridge cool.What is the problem please?
Re: I have an Amanda side by side, the fridge temp
Look in the freezer side for a ice buildup on the back wall.
Ice= defrost parts issue.
Check the fan in the freezer. Is it running?
Not running? Could be a defrost thermostat issue or a bad fan motor.
Bottom freezer fridges are especially susceptible to
Dust build up on the condenser coil that impedes heat transfer to the outside from inside the box
Remove the (bottom) footplate by grasping outside edges and pulling/levering out and popping it free.
Use vac crevice attachment and coil brush to clean away all dust from the coil and foot plate.
Replace plate and allow 24 hours for inside temp to stabilize.
Adjust top temp setting if needed to maintain safe temp level.
Repeat semianually or annually as scheduled maintenance--depending on the dustiness is fridge's location.
Airflow blockage through the crispers and meat keepers.
Remove crispers and meat keeper as well as glass cover shelf.
Find cooling passages between crispers and at midline of meat keeper.
Remove any buildup of air blocking debris.
Wipe up fridge box floor beneath meat keeper.
Reinstall glass shelf, meat keeper, and crispers.
Check perodically for poor temperature/moisture keeping in crispers and for water pooling on fridge box floor as signs of blocked air flow through criispers and meat keepers.
seeing that 32 is freezing point of water,its not suprising that food is freezing.it should be 38f or +3c.when was the last time you did a FULL defrost(NO HAIRDRYERS PLEASE).ALSO CHECK DOOR SEALS ARE TIGHT ALL ROUND.
Most likely, the evaporator coil is covered w/ice, obstructin the air flow thru it and to the fridge side of the unit.
Remove freezer back panel (where the little fan is) and check for iced evaporator coil, if so, unplug unit and use a heat gun or hair dryer to melt ice, make sure all ice is melted andthe air duct going to the fridge is clear.
Once this is done, restart unit and set temp. 1/3 of the dial, ie. if the dial goes from 0-9, set it on 3. wait 24 hrs to make adjustments
Since refrigerators were designed to run in your 72° kitchen, when you put a fridge outside, where its colder than normal operating REFRIGERATOR temperatures, i.e. 35-40°F, because that ambient temp is colder than fridge temp, the thermostat in the fridge section reads it as normal temperature, and does not turn unit on. it does not read what the freezer temp is. You have a couple of choices: bring the unit inside, heat your garage, or only use it for pop and beer in the summer. You can reply here or send me a question from my website: www.FixMyFridge.net
. Cut everything off for a few minutes then turn it back on
and listen for a click from the compressor relay as the compressor tries to
start.
Is the compressor motor running.If no check starter/overload
relay. Check to see if the
condenser fan at the back underneath near the compressor is running. If no
check fan.
Are the condenser coils near there warm or room temp. should
be warm
