Brother IntelliFAX 4100 Laser Fax Logo
Posted on Mar 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Intellifax 4100 e series- we replaced the drum
The unit continues to indicate the drum needs replacing
Karo Shito
Level 2:
Habit-Forming:
New Friend:
  • Brother Expert 70 Answers
  • Posted on Jan 25, 2016
Karo Shito
Brother Expert
Level 2:
Habit-Forming:
New Friend:
Answers
70
Questions
0
Helped
61787
Points
409
Clean the drum or do a hard reset. Check the user manual here: Brother intellifax 4100e manual
Anonymous
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Mar 25, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
Helped
3039
Points
14
Clear the drum counter.
open the front cover leave it open and then press clear button hit number 1 for yes and that's it.you can close the front cover. :-)
any other questions please let me know.
How do I replace the toner in my Brother Intellifax 4100? The new toner cartridge just arrived, but this is the first time we have had to replace it.
Open the front of the machine. Lift and pull the whole unit (drum) out. Once you have it out it's pretty simple to remove the old toner from the drum and install the new one.
Toner on paper edges
The cleaning blade inside of the drum unit is worn out. Replace the Drum Unit
5helpful
2answers
New drum replaced,but machine still ask for new drum
Wow. It's obscure and in the manual on page 13-24. Remove and replace the drum leaving the front cover open. Press CLEAR and then 1 to answser the Replace Drum YES question.
1helpful
Resetting after replacing Drum
should be in the box with the drum. if not open front cover touch clear key touch number 1 key
2helpful
Black pages
Try to copy a document. If the copy comes out black then the the scanner is dirty. Clean the scanner glass (products on the market that clean by sending through the scanner) and try to copy again. If after cleaning the scanner, the copy is still black you have a scanner issue and the laser/scanner unit will need replacement. Best of luck and please post back with any questions or just to rate the solution.
Greg
2helpful
Error 7C
There's no manual for "machine error 7C" in Bro IntelliFax 4100. To fix this issue. You will need to pull out the toner. Note: the toner and drum are connected.....At the left corner of the drum. You will see a blue tab......You will need to slide the blue tab back and forth for 20th times....And put the toner back in its place.....This is just a temp fix but you need to replace the drum to have it working its fullest......
Fuser & Scanner are not the problem
Either the laser unit is dirty or blocked. Or the drum cartridge.
Intellifax 4100 grinding noice
Probably caused by the toner cart. Only use genuine new Brother brand supplies. Remans fail quite often with Brother machines.
Possibly bad gears on fuser drive. But with the poor print quality, I suspect it is the toner.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Brother Intellifax 4100 - drum needs replacing
The drum is what the toner goes into. DR-350 or a similar #. You can get at staples or office max.
Norman Weimar
Norman Weimar
k24674
