Cameras Logo
Anonymous Posted on Mar 30, 2013
Recently came into possession of a Vivitar DVR 785HD "Action Camera." What I'm wonder is, is there anyway to set the correct date and time for videos and pictures? Right now when I shoot videos, t
  • Mark Michael Sep 16, 2013
    Called Vivitar, this model does not support setting time and date. Its a cheap little throw away that apparently no one thought we would ever want to know the time date we took a video. Won't be buying anything from Vivitar again.
Mac Harper
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 26, 2014
Mac Harper
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1481
Points
Software links for Vivitar Image Manager: http://www.vivitar.com/downloads/vivitar_mac.dmg
http://www.vivitar.com/downloads/vivitar.zip
If you download images from Vivitar 785HD using Plug-and-Play, date and time are related to the creation date of the memory chip. Use Vivitar software, image time will be correct. If you use Mac OS X 10.9.2, iPhoto will allow you to change date and time on images either individually or batch.
I just got my third 785HD (first two were defective from Staples). It works fine. Vivitar help line has prompt response,
The Sakar International Team
http://www.sakar.com/
1-877-397-8200
my email is:
[email protected]
Anonymous
Level 3:
  • Cameras Master 32,281 Answers
  • Posted on Mar 30, 2013
Anonymous
Cameras Master
Level 3:
Answers
32281
Questions
Helped
7911842
Points
102259
Go into the Camera's Menu settings, scroll through the settings to Set the Date & Time.
  • Anonymous Mar 30, 2013
    If this action camera has a menu (for settings or anything else for that matter), I have yet to find it.
  • Anonymous Jul 07, 2015
    I cannot find it either.
5 Related Answers
Anonymous
  • Posted on Feb 08, 2008
SOURCE: vivitar 3720 digital camera
,,,push the "square" button in the middle of the direction arrows.
..press the right arrow across untill you come to Date and Time
...press the down arrow to select the "set" and press the square button again
....use the up and down arrows to select the correct date
....use the right arrow button to set the month and day and so on.....
Also, if you don't want the time displayed on the picture, just select "no display".
I hope this helps!
A
Anonymous
  • Posted on Sep 26, 2007
SOURCE: blurred night time football pictures
The standard canon 75-300 lens is not considered a "fast" lens. Because of this, when zooming in on objects you are actually reducing the amount of light hitting the image sensor. Fast lenses cost $$$$. Just google "Canon L Glass" and you will see what I'm talking about. Try opening the field of view (zooming out) to allow more light to be absorbed bu the image senor. Crop your subject later in whatever software you use. You can also use one of the manual modes and up your f-stop to make the camera more sensitive to low-light conditions (higher f-stop means higher film speed.. higher film speed is how fast the "film"... aka image sensor absorbs the light. for action photos, faster film speed is key!!). have fun experimenting.
Anonymous
  • Posted on Feb 26, 2008
SOURCE: Putting the date/time stamp on my pictures
I have the same problem, if someone solved this, please let me know [email protected]
Anonymous
  • Posted on Sep 21, 2008
SOURCE: HELP! Getting the date/time stamp off your Vivitar 5100...
When you turn on your camera, press the menu button. That will bring up the screen that has the orange buttons at the top (Capture) (Setup) arrow down using the buttons on the far right side. The down button will be the dame button that you use to delete pictures with. When you get to the botton of the page continue arrowing down and that will bring up another page. Arrow down until you get to the botton there are only 3 items on this page and the bottom item will say the following:
Date imprint ON
Press your enter button (ok button) and up will pop ON or OFF.
Arrown down to the OFF and press enter and that will remove the date imprint from your pictures.
Hope this helps you.
Anonymous
  • 423 Answers
  • Posted on Feb 24, 2009
SOURCE: Jazz HDV178 horrible picture quality
This camera is an inexpensive camera that takes great videos. But it doesn't have a dedicated shutter for taking still images.
You are going to find an increase in picture quality if you hold it very still, perhaps use a tripod, or put it on something stable to take the picture. Also, make sure the you have plenty of light for your subject when you take the picture.
There is not setting that you can change to fix this. Sorry, it's not what you wanted to hear, but don't let it stop you from rating my solution a fixya.
Rob
How do i turn on my vivitar dvr 785hd It's led is showing it is charging but after when i try to turn it on it is not
Try holding your start button on your DVR and your wi-fi button on your router for about 10 seconds, holding them both at the same time and see if that works. It worked for me.
HOW DO I DOWNLOAD VIDEO ON SD CARD IN VIVITAR DVR 786 HD
PDF]DVR 480 - Vivitar
www.vivitar.com/files.../DVR_785HD_Camera_Manual.pdf
VivitarDVR 785HD. Action Camcorder .... Your digital action camcorder supports a Micro SDMemory Card (up to 32GB). In order to use your digital ... You can download the pictures and videos without the software by .... HD(1280×720)@30fps.
Amazon.com: Vivitar DVR786HD Full HD Action Camera ...
www.amazon.com/Vivitar-DVR786HD.../B00DM35U...
Amazon.com, Inc.
Rating: 3.8 - ‎19 reviews
Vivitar DVR786HD Action Digital Video Camera, Colors May Vary .... Vivitar's DVR787 HD Action Camera allows you to record amazing footage from your point ...
Amazon.com: Vivitar DVR786HD Action Digital Video ...
www.amazon.com/Vivitar-DVR786HD.../B00DM35P...
Amazon.com, Inc.
Rating: 3.9 - ‎44 reviews
3answers
Vivitar DVR 508NHD manual is not the same as the 508 manual which everyone keeps listing. The camera isn't set up the same. Where can I find the actual manual for DVR 508NHD - this is so frustrating?
Manuals online say they have them for download but after download it was a DVR 508 HD
Only thing I can suggest is buy another with a manual in the package
I purchased a Vivitar DVR action camera last June 2014 . Today 2/28/15 I used it for the first time . Got home to play back the video on my computer and it won't turn on at all . Charged it up for a couple...
The lower end dvr action cameras made by Vivitar got bad reviews and were poor performers and didn't last 3 days in some cases; you didn't mention the model you have...anyhooo
Perhaps the re-chargeable batteries have met their end-of-life date and need to be replaced; can you turn on the camera using the charger cable while it is still plugged into the wall outlet?
Vivitar dvr 785hd wont turn on
Remove the battery and try to charge the battery, before you put it back in. If you have a multimeter, try to measure the voltage of the battery. It should be just a few tenths of a volt higher than what is printed on the battery. Before reinserting the battery, check the contacts of both the battery and in the camera. They should be clean and shiny. Only to be cleaned with a dry cloth is needed. Then reinsert the battery and try switching it on again.
If it still does not work, you should visit a service centre or repair shop. But I think (most of the time it is) the battery is the culprit.
LawMate PV-AC30 manual
To set the time / date stamp you'll need your remote control and you'll need to hook it to a TV with AV inputs. Be sure to correctly select the AV input the camera is plugged into. This is the most overlooked step that causes a lot of users frustration.
I've attached a YouTube video on how to accomplish the time/date setting.
How do i set the time on my Vivitar DVR410 Digital Video Camera
Unfortunately the Vivitar DVR 410 Camcorder does not have a time/date stamp feature, therefore does not have a menu option to set time/date.
3helpful
Vivitar 3720 digital camera
I hope this helps!
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
