Ice is made and dumped into container. Water is also dumped in to the point that one large ice block forms. How can I stop the water dumping into the container?
Thanks, EEP
I had the same exact problem in my 532. Had service technicians over twice, each time they fixed the problem for only very short amount of time. Very frustrating! So I decided to fix myself. I removed the screws from the ice maker and lifted the panel, and flipped ice maker backward, so I could see the issue. The problem was the water tube which supplies the ice maker with the water to freeze into cubes. It's designed poorly and just slightly too short. I had black tubing on hand from a flower box drainage project I previously worked on, and it fit perfectly inside the short tube, which extended it enough to solve the problem. I extended the tube only about a half inch. No more solid drawer of ice. Now I get perfect ice cubes again!
