Vtech InnoTab 2S Wi-Fi Learning App Tablet & Backpack Bundle: Pink Logo
Melodie Freeman Posted on Mar 29, 2013
Innotab 2s can't connect to computer via USB.
Innotab says connected to Computer but Learning Lodge says Vtech device not found. Please help!
Rae Jimenez
Level 1:
New Friend:
  • Contributor 58 Answers
  • Posted on May 14, 2014
Rae Jimenez
Contributor
Level 1:
New Friend:
Answers
58
Questions
0
Helped
17704
Points
83
Try another USB cable/usb port. if that doesn't work: For windows--check under device manager>>disk drives>>look for vtech nand1>>right click--uninstall>>unplug the toy>>plug it back in>>turn it on>>try to access Learning Lodge again. For Mac>>open Disk Utility while toy isnot connected to toy.>>plug toy to computer>>turn it on>>look for anything that says vtech.if you do go to Learning Lodge--send error report--call vtech
2answers
Cant get learning lodge to reconize innotab 2
Try another USB port, USB cable or another computer.
Troubleshooting why does my innotab 3s not get recognised
You must install the InnoTab 3S version of Learning Lodge. If it doesn't automatically install, you can install from setup files on the VTech website. Download the manual at http://www.manualslib.com/manual/551479/Vtech-Innotab-3s-The-Wi-Fi-Learning-Tablet.html
Jun 28, 2014 • Baby Gear
Blank screen
updates for the Innotab are automatic. plug the toy to your computer and connect it to Learning Lodge.
Computer not recognizing the tablet
Hi Bre. for the registration, maybe you registered the toy to the vtechkids.com website? the registration for the Learning Lodge and the vtechkids.com website is different. If you are sure that you have registered the toy to the Learning Lodge, I suggest that you go to My ACcount. You will be asked for a password. Click the forgot password option and you will see the email address that you used when you registered for a learning Lodge account. As for the toy not being recognized by your computer, try another USB cable 2.0, another USB port in your computer. If that doesn't work, double check under device manager (assuming that you are using a Windows computer) or Disk Utility App (for Mac). Once you are in device manager click Disk Drives and check if you see anything that says vtech. if you do, right click on VTECH nand1 and uninstall. after uninstalling, turn the toy off, unplug it from your PC Plug it back in and turn it on. Try to access Learning Lodge again. I hope this helps.
1helpful
2answers
SYSTEM PROBLEM FOUND
You need to update the toy. Connect it to your Learning Lodge Navigator. You should be prompted for an update.
2answers
I got my daughter a vtech innotab 2 but dnt have the installation cd which has the learning lodge navigator on. does any 1 no where i can get the learning lodge nav frm?
You can find instruction on how to download the Vtech Innotab Learning Lodge Navigator here: http://www.vtechkids.com/support/faq/%7B3A3839B6-B8FC-4109-B51D-E26EAAA31508%7D/lightbox/
Can't get Learning Lodge to reconize second device
is the other toy also an Innotab 2? are you getting any error message? You should see a blue circle that says connected on the Learning Lodge.
Top Vtech Toys Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Vtech Toy Expert? Answer questions, earn points and help others
