Replaced door switch about a month ago when micro or convection wouldn't work. Now convection works but not micro. Has burning rubber smell.
SOURCE: Ge JVM1190 appears to be working but does not cook.
I spoke with a qualified microwave technician who advised me to buy a new microwave as the problem I was having indicated that the magnetron tube had blown. What a waste of time to ask for help from you.
SOURCE: JVM1190 wont cook
You have a blown actuator. This is the device that creates the microwaves that cook the food. The cost of one of these will be as much as a new unit.
SOURCE: Burning Smell in microwave/convection oven
Assuming your inside light and turntable come on when you try to microwave, with the symptoms you
have, I would most strongly suspect a shorted high voltage rectifier
diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
If
it's within the magnetron portion of the warranty (usually 5-9 years)
but out of the original full warranty (usually 1 year), then your
manufacturer will cover the part cost, but not the cost to visit you or
the labor charge to do the work.
GE Customer Service is here.
Otherwise, the diode is a fairly
cheap fix, and the mag will cost more.
If you or someone you
know
decide to look into it, we have critical safety information and
disassembly information at our site, and our link is at our listing here on FixYa.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
You can usually find
helpful exploded view diagrams and order parts by entering your full
model number here.
Here are some links you
or someone you know can use for test help, but read their safety
warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's
probably okay)
http://www.gallawa.com/microtech/mag_test.html
We're happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer.
SOURCE: The microwave part of GE profile JVM1190
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
SOURCE: Problem with the GE Advantium
sounds like the magnetron. Youll have to have a technician replace it. if you have a warranty just call the company and they should take care of you.
