SOURCE: Please let me know how I can change the rear tires
I want to add additional traction to my John Deere electric Gator. I have heard that you can somehow slip a bicycle tire over the plastic tires. Has anyone done this and how do you do it?
SOURCE: i got a john deere gator 4x4 hpx, it will not run
Remove flywheel shroud to see your timing marks,they will be 90 degrees apart on face of flywheel.Use timing light on flywheel as you look directly at it from the side.when light flashes you should see the marks lined up with arrow at the center top of block breather cover.If you find that your timing is off there are only 2 things that it can be-FLYWHEEL KEY or the computer located at the rear of engine.I have only had 2 machines where the timing was off exactly 90 degrees and the computer had to be replaced both times.
SOURCE: I need the instructions to assemble John Deere
I had the same problem and needed a parts list so I finally found it at
this peg perego parts site
the company is
http://www.shopjandl.com/fius0101g24.html
and they were really helpful with my other repairs
Hope this helps
SOURCE: where can i get a rubber tires for a Peg Perego
the whole tire would be difficult to replace with a rubber one, but you can put bmx tires on the plastic wheels and that will give much greater traction, but shorten the life of the gearboxes. here is a link to how to do it.
http://www.youtube.com/watch?v=AAySJVt6bys
