When replacing the batteries the guy shorted them momentarily and burned himself. Did he ruin the battery/ies?
SOURCE: Jet 3 Ultra won't charge
Indeed, you need to find a repair shop. Try a google search for power chair repair, or ask your local hospital or if you can find one a power chair store. Most likely, you have a mechanical failure of the wiring, the battery themselves, or corrosion on the battery posts. Since the chair lights up when the charger is in, it is unlikely that the charger is broken. You may have a failure of the controller board, but that is also unlikely. And batteries do not usually suddenly fail completely; they typically fail slowly, losing the ability to completely charge.
I assume that you did not see a great deal of fluid leaking out of the battery container; you might look in the container and check to see if a battery is cracked or missing fluid.
SOURCE: need to remove the bad batteries Jet 3 power chair
Hello Donald ,
You may have solved this problem by now ,but just in case you have not, here goes.
Make sure the chair is turned off and engauged in the drive mode meaning not in the free wheeling mode. This way it will not roll around on you during the battery change out.
Go to the rear of the chair and slightly turn the two black plastic lock pins,one on each side they actually lock the small )) shaped cover in place. Turn these with your fingers or you can also insert a dime in the slot on top of each pin to turn them . You will be able to tell when they have unlocked as the )) shaped cover will be loose. Lift the cover up and under it you will find the battery connector, unplug it and leave the cover off for now.
Next ,move to the front of the chair and just to the rear of the footplate you will find a locking pin that runs through the lower rear bar of the footplate as well as the chair frame itself . Pull this pin completely out. Once done you should be able to pull the entire footplate assembly out torward you, Black plastic front cover included. Once you have it pulled outward lift it upward and it should lift completely off the chair. This done , you should actually be looking at the front battery which is sitting in a black plastic tray. Gently but with a firm grip grab the tray anyplace you can and slowy begin to slide it out from under the chair torward you taking care not to tangle the battery connector at the rear with any other wiring on its way out. Once you have the tray slid out into the open ,you will be looking at both batteries after which you will need to unhook the straps that secure the Batteries to the tray after which you will need grab your wrenches and remove the battery harness itself from each battery. You may want to do just one battery at a time this way you'll have less wiring to keep track of when wiring in the new Batteries. The Batteries in your Jet 3 are a size known as U-1 deep cycle sealed maint. free batts, You can use either Gel Cell or seale3d LA replacements . Though they are much cheaper, you cannot use lawn tractor batteries. Though they look the same the internal technology between medical powered mobility batteries and tractor batteries are entirely different. The latter would only run your chair for maybe a half hour or so before needing charge.
Take great care to make sure your wiring hookups are correct and that you position the rear connector plug to the rear of the tray. This way you will be able to locate it easier once you have slid the tray back in under the chair and it is time to go to the rear of the chair and reconnect that plug. As for everything else ,reattach it in reverse of the way you removed it including remembering to slide the lockpin back into the front footplate frame. Give a tug on the footplate when done to make sure it is locked and secure.
In closing I offer this valuable advice : When working with any of these batteries, always were safety glasses or goggle and gloves (terminals are lead). I also advise removal of metal rings ,watches, bracelets etc that could create a short when reaching in and around the battery terminal. Take great care with your tools and wrenches in making sure you keep and eye on both ends of the tools at all times. This way you will not accidentally cross the posts of the battery. Take your time ,use proper safety technique and you'll do fine. The following is Pride Mobility's step by step for battery change out and is basically the same as I have sent . Can never have to much info but can always find yourself with not enough. Take Care
To replace the batteries:
1. Turn off the power to the controller.
2. Make sure that the power chair is in drive mode. See III. "Your Power Chair."
3. Turn the rear shroud fasteners one-quarter turn in any direction. See figure 6.
4. Remove the rear shroud.
5. Unplug the battery connector. See figure 26.
6. Remove the retaining pin from the foot platform and lift the platform up and away from the power base. See figure 19.
7. Slide the battery tray forward.
8. Unfasten the reusable strap around the front battery.
9. Disconnect the wiring harness from the front battery.
10. Remove the front battery.
11. Unfasten the reusable strap around the rear battery.
12. Disconnect the wiring harness from the rear battery.
13. Remove the rear battery.
14. Place a new rear battery on the battery tray. Make sure that the terminals are facing forward.
15. Fasten the reusable strap around the rear battery.
16. Connect the wiring harnesses to the rear battery.
SOURCE: batteries not charging - just replaced
1st Check the 25amp inline fuse located behind the volt meter. 2nd Check the 50 amp fuse located behind the foot rest. A pin located under the foot rest when pulled out will open the front to access the fuse.
SOURCE: replaced batterys,and a batt charger and now have
Chk Yuor batteries you poss hooked them up backwards, Also chk your joy stick cable it might not be hooked up all the way. If you want to call me at 1-864-608-2687 Erik, I am a repair center for pride
