SOURCE: fisher & pakel dd-603ss top drawer wont drain
Have you cleaned the drain filter ? If not, clean that ( it is beneath the rack where the utensil bin is normally positioned and accessible by lifting up the plastic door..If that is clogged up then your drain flow will be restricted. Also, check to make sure the drain line is not restricted ( pinced or clogged). .And yes , the drain is pumped out. If these tips do not get you going, please write back and let me know.. will help get your dw going ...
Regards
SOURCE: How to take or remove drawers out of 2 drawer Fisher Pakel
Hi, welcome to FIx Ya...
1. Unplug machine.
2. Slide drawer open, remove two pegs that secure front panel to drawer (one on each side of drawer)
3. Slide front panel down and out, remove green ground wire.
4. Depress tabs that hold bottom plastic cover on bottom of drawer and remove entire cover, being careful not to break the tabs.
5. Disconnect tan water fill hose from rinse dispenser.
6. Disconnect two wire harnessess at control board.
7. DIsconnect drain hose from pump base. (might want to put a pan underneath to catch water)
8. Depress tabs on hose/harness coupler at bottom rear of drawer and dis-engage the coupler.
9. Lift drawer off slides.
SOURCE: Why doesn't my Fisher Pakel dishwasher drawer not clean the dishes anymore?
see the causes and fix it : God bless you
No water Entering Dishwasher
Check to make sure water is entering the dishwasher do this by
starting a wash cycle wait for it to fill and start washing then open
door. If there is no water you will need to check the water inlet valve and the float switch. This video will walk you through checking both out. Click on links to see a photo tutorial of replacing those parts.
Low Water level
This is another common problem. To check that you have the
proper water level you will need to turn dishwasher to a wash cycle wait
for it to fill, when it starts washing stop and open the door. Now
refer to the tech sheet or service manual for the proper water leve.
They usually refer to a fixed point in the dishwasher or to a specific
measurement. This ensures that your dishwasher has enough water to wassh
properly. If your water level is low you will need to check the water inlet valve and the float switch. The video
will walk you thru inspecting and testing these components. The links
will lead you thru a photo tutorial on replacing these parts.
Wash Arms
First check to see if they are moving. To do this start
dishwasher into a wash cycle wait for it to fill and start washing open
door and rotate wash arms to a certain position remeber this position
then close the door let run for a few seconds and open door. If they are
not moving check to see if they turn freely if not replace. Next remove
the spray arms and check for clogged holes. If all looks clear you will
need to check that the circulating pump is not clogged up or has failed.
Drain Problem
This is one of the most common reasons. To check open door after
a cycle and check to see if any water is standing inside. If there is
you have a drain issue. Could be the high loop or air gap is not correct.
The drain may have a clog. The drain pump may have failed. The drain
pump can be checked for the proper ohm reading (refer to tech sheet). If
it is out of specification replace the pump. Check to see if the drain
pump is getting power. If the drain pump is getting power but not
running you will need to replace. If it is running but still leaving
water behind you will need to remove the drain pump and check/replace for obstructions.
Control
This is the least likely cause.Check to make sure it goes to
each cycle for the proper amount of time. The main control or Timer has a
pre determined amount of time programmed into it. This determines how
much time to spend at each cycle. The time is usually printed on the
tech sheet. The tech sheet is located somewhere on your dishwasher. It
could be behind the front panel,behind the console, behind the toe kick,
somewhere on the sides. If it does not stay at each cycle for the
proper lenght of time you will need to replace the control.
The Heavy Wash does not wash for 127 min. now...it shows 107 min. Can I reset this?
