Im not a great expert in this field but try putting some dish washer tablets in water when running to see if they can clean out anything,about 3/4 tabs
the buttons on most of the tubes are pressurized air when u push it sounds like a bad button or hose it could even be the little air sylenoid that clicks on and of when the air is forced against it when u press the button 1st check the hoses for leaks 2nd remove hose and verify the button works
your motor thermal safety relay is protecting the motor from burning out this is usually caused by: an old motor about to fail (tight shaft bearings) bad centrifical switch or, an obstruction in the water flow causing the motor to work too hard (draw too many amps, get too hot then cool down and, start up again check the relay it is located on the side of the motor on most motors; under a cover; unless the motor is bad the relay may just be too sensitive (old) and, may need to be replaced.
get an electrician. you need to follow the code for the size of wire to use based on number of amps of the motor and how far away the pump is from the power outlet.
The heater will only fire if it has water in it. If you just got the house, make sure the gas/electric to the heater is on. Turn off the pump and turn it back on.. See if that works. good luck
yes it could, it might even be the motor, take the electric suply and unplug it see if you can turn the shaft on the motor if not it froze up,, sometimes the get wet and seize, the you have to get a new motor
sounds like the rubber seals are going bad, does it recomend to run cascade thru the jets? this might be harmful to the gaskets and the pump, you maight want to disconnect the hose and flush out the tubes going around the tub, but I would call jacuzzi and ask them if this is good to run thru there, thye might be able to help you with the gaskets, questions over the phone do not cost you, call them, ask for repairs section good luck
does it have a heater in the circulation line, it should be under the cover and would be in line on the 2 inch pipe that feeds the jets, it should also be on a gfci, check to make sure it is plugged in if this is plugged in and not tripped you need to install a new heater
Again - whirlpoo jacuzzu, but with one jet not working. Rest seem fine.
