My keyboard is locked when I turn on the phone. I did a soft reset, system reset and then a hard reset. It was difficult to get through the hard reset but I pushed all the buttons until I made it through the 4 required steps. Then, my keyboard worked and I could navigate anywhere. As soon as I turned the phone off and on again, the keyboard was locked again. Help!
SOURCE: treo 650 keyboard not working
THere is a screw just under the antenna ( remove small rubber plug with a sharp knife) and the keyboard can be replaced although I had a similar problem and it was the ribbon not seated all the way into the holder.
SOURCE: Receiving MMS on Treo 650
This device should be compatible with MMS.
I found this thread which might help you set up MMS on your Treo 650. Look at the 2nd entry:
1. Start, Settings, Connections, and then tap the Connections Icon
2. Under "My Work Network" tap Add a New Modem Connection
3. Name it Picture Messaging and under Select a modem select (GPRS,3G)
4. Under Access Point Name type: wap.voicestream.com
5. Username, Password, and Domain is left blank and then click Finish
6. Now, go into Proxy Settings and check "This network connects to the Internet" and check "This network uses a proxy server to connect to the internet"
7. Under the Proxy Server box type: 216.155.165.050
8. Tap the advanced button and tap on the HTTP line. Make sure the HTTP settings shows 216.155.165.050:8080. If not, change it.
9. Click the OK button a few times to get out of the settings completely.
10.Now go to Start, Messaging, Menu, then Options, Advance, then Click Manual, and then the Edit button
11. Message center number +12063130004
12. Email center number is 500
13. MMS gateway address is 216.155.165.050:8080
14. MMS URL is http://216.155.174.84/servlets/mms
15. Finally under Network Profile select: My Work Network and then click ok.
SOURCE: Palm Treo 650 Unlock Code.
do u have a unlock code for your treo 650?can u share me a code so that i can unlock my treo 650 here is my messenger and email account [email protected] i hope you can help me too.
SOURCE: TREO 650 Phone won't work
I experienced the same problem while traveling this weekend. The green phone button and anything associated to the phone all of a sudden stopped working. No call out and none in. I hotsync'd and also did a "hard reset" except I said yes and then went in and hotsync'd again. Phone now works again and all data is back
SOURCE: MY TREO 650 KEEPS TRYING TO HOTSYNC(and its not connected to computer)
how to hard reset my palm treo 650
