Question about Maytag EPIC MFW9600S
Suds and F02 Error codes.
I've changed the pump, cleaned trap, and cleaned the discharge hose. I'm still getting the error codes. Does anyone have anymore ideas? Thanks
  • Leslie Reichardt Apr 13, 2013
    Well it's not a level switch. If it's a control panel or board would it be the interface, main control, or the pump?
  • 1,010 Answers
You did all the right thing, now it could be the control panel
Posted on Mar 29, 2013
SOURCE:
  • 96 Answers
SOURCE: SUDS error code
I suggest you disconnect the tube from the water level control pressure switch and blow it out well. Then, if need be, disconnect the drain hose and make sure it is clean as well.
Posted on Mar 14, 2008
SOURCE: F02 Error on Maytag Epic.
I just wanted to confirm stopgo's solution. A few notes/elaborations:
  1. Open the front door of the washer, and run your hand behind the big, gray rubber gasket. You might feel/see small items stuck there.
  2. If you kneel in front of the washer and look along the very bottom edge, you'll see 3 screws in a row. They are of the "torx" type. Unscrew them and then jiggle out the bottom panel. Inside you'll see a large plastic (off-white color) drain, and you can unscrew the 3-inch diameter cap off it and pull it out. The backside of the cap is a filter. Clear it out and put it back in. (We found a baby sock there).
Note also that when you pull out the bottom panel and look inside the cavity of the machine, there is a special manual for service technicians, stuck on the inside wall. I pulled that out -- there were some interesting/helpful information on that sheet telling you how to troubleshoot problems, including checking the drain filter.
Funny that the instructions for checking the drain filter cannot be accessed until you open the bottom panel to check the drain filter!
Posted on Dec 22, 2008
  • 750 Answers
SOURCE: Start the wash . Lets say quick wash . error nd
HiYa ngateley
"nd" refers to a No Drain issue . check for restriction in pump assy, restricted drain hose loose wire at pump, bad pump.
please leave a solved rating before you sign off.
Posted on Apr 07, 2009
woobie dog
  • 1273 Answers
SOURCE: What causes the SUDS error code What sensor is
Hi Ron,
I found most of this on another site, and am including it here for your enjoyment. The problems are listed sort of in progression; try step 1 before 2, etc. It sounds like the tech gave you the most common cause and solution, but it sounds like two cycles may be necessary to rule out the detergent solution.....it usually is though. But WAIT! There's MORE!
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If “Sud” is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
• Check / Clean Drain Pump Filter of foreign objects
• Check Drain Pump
• Check the Pressure Switch
• Check CCU
Replace failed component.
I hope you found this to be of help, and at least mildly entertaining!
Best regards, --W/D-- please feel free to rate his solution!
Posted on Jul 30, 2009
SOURCE: SUDS and F02 error codes on Maytag Washer
If it's not draining properly and shows this F02 Code there may be a simple solution. Take the bottom front panel off (it has 3 screws.) There will be an off white circular plastic thing there. Resembles the top to a cannister. Twist it off. There will be a good bit of water if it hasn't drained properly. I put a cookie sheet under it to catch most of the water. Once you completely unscrew the top off hopefully your problem will be right there. Unbelievable...we found 2 socks, a glove, a bead, coins and don't ask me but there was a nail in there as well. I was so happy that we didn't need to pay a repair man.
Posted on Aug 13, 2009
Suds, F02, clicking sound from drain pump/motor
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Nov 24, 2011 | Kenmore Elite 45986 Front Load Washer
Hello My Maytag black front loader washer is displaying an error code of F02. Do you know a fix for this error code? Thank you
F02 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 07, 2011 | Maytag Washing Machines
What does F-02 flashing on the display of my Whirlpool Duet washer mean?
Kevin
Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F02
The f02 error code is caused when the unit control thinks there is still water in the tub after it has tried to drain. If the washer is full of soap suds it will also display an f02 error code. You will need to use only name brand HE detergent. If your washer is not draining the water out you will need to clean the pump filter. I have provided the instructions below. Run the washer in a drain and spin to ensure the pump is running. If the washer has no water and no suds the problem will be either the pressure switch or a plugged pressure hose. To check the pressure hose you will need to remove the top and remove the hose from the pressure switch.
Jan 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a kenmore elite oasis 110.27042602 with fault code f2. Should I try replacing the control board? I already cleaned the contacts on it. Thanks!
Hi
Error F02 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Jan 25, 2011 | Kenmore Washing Machines
Getting F02 error on Kenmore Elite HE3 washing machine............how do i fix problem?
Hi
• Check the drain hose and make sure it is not plugged or kinked.
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects.
• If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap. Hope this helps... Please post back for more information.
Daniel
Nov 26, 2010 | Kenmore Washing Machines
Keep getting F02 code, cleaned all the hoses, cleaned out the trap in the pump. goes through the first part of the wash cycle just fine, get's to rinse and hit the F02. Is the pump bad also keep getting...
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^%*&(
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our Whirpool duet washer will not spin, gives us the SUDS and F02 message and now the door is locked.....suggestionss?
k now the washer beleives that it is full of water.
pour about 3/4 cup of veg oil in the dispenser. and start the unit.. this will get rid of the suds error.
F02 means long fill.. and the water level has not satisfied the computer for 40 secs. check water connections. making sure they are fully open.
to open the door if it does not unlock, in the dispenser there should be an ODD colored line, five that a tug and the door will pop open
Oct 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool DUET that continually gets F02 msgs. I removed the inner and outer drain hose and cleaned them out. I cleaned out the drain pump filter and the large diameter rubber hose at the bottom...
"F02" is a Long Drain error (as you well know by now). The error code is generated when the drain time exceeds 8 minutes. If the pump motor or impeller is damaged and it is not pumping at the correct volume, the error code will continue until the pump is replaced.
I applaud your effrots. You isolated the source and did all the necessary steps required to clear this error code, but if you perform all these preliminary measures and still have problems, the rule of thumb is to replace the pump.
The "SUDS" error can occur in conjunction with the "F02" error. If the pump is not functioning properly and air is detected in the drainage system, you will get the SUDS error as well.
"F09" is an overflow condition error code which has many causes, inlcuding the drain pump. Everything seems to point to the drain pump in this one. Replace it and your problems may go away.
A replacement can be purchased at any of the following web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Use whatever part source you like, but I have found these sites to be the most reliable and offer competitive pricing.
If you have questions, or need additional assistance, please let me know. I hope this helps you.
Sep 02, 2009 | Washing Machines
Kenmore Elite washer HE4t keeps giving us a F02 error code??
Check the drain line for kinks or obstructions. The pump should also be checked. Remove the hoses from the pump and using a flashlight, look into the suction port on the pump. Make sure there are no obstructions (like the occasional stray sock). Also check the pump impellers and make sure no blades are missing/broken and that the pump impeller spins freely. If any blades are missing/broken or if you cannot get the impeller to spin freely, the pump is defective. Sorry for your trouble and I hope this helped. Best wishes.
Aug 28, 2009 | Kenmore Washing Machines
Maytag EPIC MFW9600S Logo
99 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
