Dryers Logo
Posted on Mar 03, 2009
Hotpoint Ultima Condenser Dryer - where is the reservoir?
I have a hotpoint ultima condenser dryer and the light says reservoir full but i can't find the reservoir to empty it. Can you help?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 01, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
588
Points
Under the door, you need to take the small panel off and its there.
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Mar 03, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1133
Points
1helpful
Hotpoint ultima tumble dryer
sounds like its blocked with fluff somewhere and your element could be wet take off the back and check your element and if water around it you need to compleatly clean out your filters and down where the condenser is then leave it for a day or two to compleatly dry the element
8KG ULTIMA TCD 980 condense tumble dryer : the excess water isn't going in the bottle
How do I change the belt on a Hotpoint condenser tumble dryer
Aug 25, 2013 • Dryers
Hotpoint Ultima Condenser Dryer TDC62 - No Heat
That trouble is cause by an heater that is already open- no connectivity. Also the wire connected to it.
I hope I answer your problem.
My Ultima condenser dryer keeps cutting out after 7-8mins of running. Ia this an overheating fault? How can I fix? Lawrence
have you cleaned all the filters so that it can work properly also are you over loading it. and the machine might be to close to the back wall hope this helps.
Hotpoint ultima condenser dryer TC71 is running cold
Thermostats rarely go. You could have a bad heater or even a voltage problem. Even if the dryer runs, the voltage can still be wrong, it only needs 110 volts to start the motor but must have 220 to have heat.
Apr 06, 2009 • Dryers
2answers
Drum wont move
Check the motor and the belt on the back of the unit behind the rear plate. Make sure that the belt is attached and the motor is spinning. If this helped please rate. Thank you
I have a hotpoint ultima 7kg condenser dryer which is leaking from underneath and not drying
Check your user manual for faults to be found at the rear of the manual.
If you don't have a manual go to www.hotpoint .co.uk.
Click on After sales, then on download user manual.follow instructions.
Good luck.
Please leave feedback.
Nov 30, 2008 • Dryers
11helpful
4answers
Hotpoint ultima wt741
hi i have a hotpoint condenser tumbledryer with the eroor code f11 coming up its a hotpoint ultima ctd85 can anyone help pls
3answers
Ultima Condensor Dryer
on the back of your dryer you have a heater behind the protruding panel... Either you heater element has gone, but most like the thermal cut outs have blown...these are located in the same area..they are small and round looking and are connected to them are wires either side. Anyways check the conitunity of the termal cut outs using a tester if no continuity then they are no good... hope it helps...
Top Hotpoint Dryers Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
