I am in hell programming a TE-2400 cash register and am stuck in a number of places. I need to program a MISC key so we can ring things up by price instead of PLU if need be - you know, 9.99 MISC, for example. I will stop there for now as I'm sure I'll have more questions over the next 72 hours. Of course we are in ER mode because the old register in our store died (was killed). THANKS in advance!
SOURCE: casio te2200 cash register programming
Hi Cathy,
You sure have been programming the Departments. You have turned on a link feature to a condiment PLU, so go back, and turn that off for the departments that you have it set to on. The digit limit has also been set too low, so now the machine has been told to accept low amounts only in those departments, so you will need to go into those departments, and set the Digit limit (sometimes called HALO) to a higher value.
If you don't know what you did to cause this problem, just do a program read of the departments, and have a look at the ones that work, then set the others to the same values.
If you still have problems, then type out the values of a good dept, and a bad dept, and I'll tell you the difference.
Mark
SOURCE: Need free programming manual for Casio TE-2000 cash register
Hi. I don't have any downloads, but I know this model, so I can help with programming.
Mark
SOURCE: Programming Casio TE-8000f cash register
please download your programmers guide/manual from the below link>>
http://www.premiercash.co.uk/brochures/TE-8000_User_Manual.pdf
please rate this solution.
Thanks for using FixYa.
SOURCE: How to merge (not found PLU) into scanning PLU file in casio te-4
Hi.
This is the only thing I haven't managed to do with them. I've tried many methods and consulted other techs, but it seems they are very separate memory areas. You will probably just have to program the product into the scanning PLU file as well.
If I find a way, I'll try to post it for you.
Mark
SOURCE: TAKE A FORCED CONDIMENT OFF A PLU ON A CASIO TE-2400 CASH REGISTE
Hi.
Try this:
Turn key to program mode.
3 SUBTOTAL
0
PLU button
SUBTOTAL
If you had tax on this button, it will need to be set again. Just let me know if it is not calculating correctly.
Mark
