The error code 1F on an LG refrigerator indicates a problem with the ice maker fan. The most common cause of this error code is frost or ice buildup around the fan. If you have disconnected the water line to the ice maker, then the most likely cause of the error code is frost or ice buildup.
To fix the error code 1F, you will need to defrost the ice maker fan. This can be done by following these steps:
Unplug the refrigerator or turn off the circuit breaker that powers the refrigerator.
Remove all food and drawers from the freezer compartment.
Open the freezer door and allow the ice to melt.
Once the ice has melted, use a hair dryer or heat gun to melt any remaining frost or ice around the ice maker fan.
Wipe away any moisture with a clean cloth.
Reassemble the freezer compartment and plug in the refrigerator or turn on the circuit breaker.
If the error code 1F persists after defrosting the ice maker fan, then there may be a problem with the ice maker fan motor or the control board. In this case, it is best to contact a qualified technician for assistance.
Here are some tips to prevent the error code 1F from coming back:
Keep the freezer door closed as much as possible to minimize air circulation.
Defrost the refrigerator regularly, even if the ice maker is not in use.
Clean the ice maker coils regularly to prevent frost buildup.
If you live in an area with hard water, consider using a water softener to reduce the amount of minerals in the water that can contribute to frost buildup.
By following these tips, you can help to prevent the error code 1F from coming back and keep your refrigerator ice maker working properly.
Not a whole lot you can do but to keep the frost down.
If you are able to move the items in the freezer to another freezer and let it sit overnight, all your problems will melt away....
Until a couple months later when it builds up
Make sure to double check your freezer is sealing correctly, bad gasket causes moisture to be sucked in.
When frost builds up on the little flapper at the top of the door above the ice maker it can get stuck. It tells the ice maker to keep making ice. Try cleaning the mechanism of frost and make sure it operates freely.
look at the chute where the ice comes out the door and see if the door in there is sticking open and leaking air in some times it helps to hold a flashlight on the out side aimed up the chute while lookin down on the inside
