I want to take the SD card from my Canon Camera and insert in the SD slot of the Asus. However I have forgotten what to do then
You should get a popup. You didn't specify the Model of Asus, try here for a User Manual: http://www.asus.com/Eee_Family/Eee_Reader_DR900/
SOURCE: I have got a SONY PSP memory card stuck at the
Damn, I hate it when that happens.
I have had to use a very small pick (like a dental pick) to drag them out of my laptop.
SOURCE: built-in SD card reader (ASUS Eee PC 4Gb) is not working!
Try here> http://support.asus.com/download/download.aspx?SLanguage=en-us
SOURCE: when i insert the micro sd into card reader slot
Please check the card with another device to confirm that the SD card is in order. If so the slot reader can have fault on the contacts or that the PC driver port of the slot has errors. You can try to restore the PC to an earlier date or reinstall the drivers.
SOURCE: cant read SD card on
The question is is it the slot or the media? You can get an external card reader for about 5 to 10
bucks that will hook up into your computer. Test the media with another computer if you have access to see if its the media that the problem.
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
Note:
