Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.prounlocking.com/samsung-a707/rs8wp9/
Hi, when a phone displays an insert sim message, it means that either the Sim card or the Sim tray where the sim card is inserted in the phone.
First, You can use the sim card on another phone to be sure that the sim card is still working properly. If the sim works with another phone, that means the sim tray where the sim card is being insert into the phone is bad and will need to be replaced.
You have most likely already checked this, but just in case.....make sure the sim card is full inserted, and inserted in the correct position. (There should be a diagram showing which way to insert the card.
