Question about Inverter Vector 400-Watt Power
2nd season with 400 watt vehicle 1024 inverter. The
2nd sason with 400 watt vehicle 1024 inverter. The power light goes on then the red light flashes slowly. After restarting vehicle and or inverter it works but same problem occurs again.
  • 4 Answers
Restating the question - 400 watt inverter is turned on and running with the vehicle turned off.
After starting vehicle the red light of the inverter is on with no power output from the inverter.
If you turn the inverter off then on inverter operates normally.
Solution - this is normal operation - my inverter does the same thing. When you start the vehicle
it draws a lot of current from the vehicle battery which causes a drop in battery voltage. Most inverters have a low voltage input safety and will fault the device.'
If the problem is turn on inverter then the red light starts flashing... I am thinking you
have the same problem as the one I replaced - it broke... I am sure some capicator
or other component in the circuit failed... My solution was to purchase a new one...
Posted on Mar 03, 2009
  • 26 Answers
These inverters are notorious for this. Like the previous posting, it is probably a bad capacitor or other component. Try to keep them unplugged when you start the vehicle. The power outlet gets a jolt of DC voltage on startup. I recently bought the one below and it has been working great for quite sometime: http://batteryinternational.com/400-watt-power-inverter.html
Posted on Oct 22, 2009
6ya staff
SOURCE:
I am running a Whistler 400 watt power inverter and have issues with the Isuzu lighters urning out wires or blowing the inverters. I am running an PH mini computer with touch screen and a Start micronics...
If the inverter is blowing your vehicle's lighter socket fuse, does it do it immedately or only when you try and operate a device? If its when you operate your device, it may draw more than 100-150 watts. This wattage is the limit for most lighter sockets. Double check the devices power requirement.
Dec 07, 2010 | Whistler Power Inverter
I just bought a power inverter for use with my pc.
There are two possibilites: the first is the over 400W power draw, the other is how you have the inverter connected. Do you have the inverter connected directly to the battery terminals (the clips) not the outlet plug (cigaretter lighter)? This is needed for any load over 80W and under 400W. (the inverter can handle a load demand over the 400W limit but only for short periods (800W).)
What is the load that your PC pulls (Is it a laptop or a desktop)? The laptop in my home has either a 65W or a 90W load (depending on the battery and the AC adapter we are using). Desktops take much more power (usually).
I hope this helps.
Jul 15, 2010 | Black & Decker Power Inverter PI400AB
My Motor Trend Inverter 400 watt give's me a fault light upon start up. The fuse is good
Sadly replacement is the best option. It is just not cost effective to get the inverter repaired.
The cost starts out about 150.00.
Best option is to take it back to where you purchased it and hope you can get a new one.
Hope this tip helps.
Am a seven each power inverters owner.
Recommendations: Purchase a Pure sine inverter 1500 watt. We have had one of these running 24 seven for almost a year now.
Feb 15, 2010 | TREND Motor Trend Inverter 2400 Watt ...
My powerline 200/400 watt Inverter is flashing the red light and sounding the alarm. This happens with nothing plugged in or just about anything.
Low input voltage or current.
Bad input voltage sensor.
Test by connecting directly to battery (with jumpers or make an adapter). The wiring or connection to your power port (cigar lighter) may be bad.
If it works at the battery, it is the car wiring. If not, it will cost more than the 25 dollar price tag to have it repaired. Just replace it (try http://search.harborfreight.com/cpisearch/web/search.do?keyword=inverter )
Dec 31, 2009 | Powerline 0900-73 Slimline Inverter
I have a black and decker inverter type 1 400
First, you should be aware that the exact inverter is available for under 40 dollars all over the US. Your model is sold under several names - check out http://search.harborfreight.com/cpisearch/web/search.do?keyword=inverter .
I suspect that your INPUT power level is not adequate for the inverter to put out the 200W that the 150W charger needs. If you have low current and low voltage - then the inverter can only put out a proportionally smaller AC wattage level. You may also have a faulty voltage sensor....at the input. Once the inverter sees a low level (even momentarily), it alarms and shuts down the output until the unit is reset (turned off/back on)
Dec 28, 2009 | Black & Decker 1000w Power Inverter
How to connect to the battery thanks
Your connection willl be governed by the size of the inverter. Some smaller units plug into a vehcile's "power outlet." This used to be called the cigarette lighter. This is usually true for inverters up to about 400 watts.
For larger inverters, you should have received a set of cables, one with a red clamp and one with a black clamp. The black clamp gets attached the vehicle baterry's negative terminal and the red clamp goes to the vehicle's postive terminal.
If you plan to use the inverter for any length of time, the vehicle should be runnig to prevent the battery from going dead.
Apr 24, 2009 | RoadPro RPPI-2500W Inverter
Inverter Vector 400-Watt Power Logo
724 people viewed this question
Top Inverter Electronics - Others Experts
ray gallant
ray gallant
Tom Chichester
Lawrence Lewis
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
