Onan Generator, 4000W, Gasoline Logo
William Novak Posted on Mar 27, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can not start generator with remote switch or with switch on gernerator
I can jump the selinoid and it cranks, but if I use eaither the remote switch or the actual switch on the generator it will not crank
Renee F
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Onan Expert 573 Answers
  • Posted on Nov 17, 2013
Renee F
Onan Expert
Level 2:
Prodigy:
Answers
573
Questions
0
Helped
247864
Points
680
The problem is the control board if neither the remote or local swiych will work. Assuming the board is plugged in correctly and proper battery voltage is present. I would NOT recommend jumping the solenoid !
98 Acura integra no crank no start issue
key --ignition switch--solenoid --failure
1helpful
My 98 buick regal won't start unless I jump across the 2 posts on the starter all fuses are good
Are you sure about the fuses? There are 2 fuses in the fuse block on the right side of the dash both 10 Amp one is marked "crank sig" and the other is "PCM-BCM" there is another in the under hood fuse block it's a 40 Amp maxi fuse marked "CRANK". If they're all good suspect the transmission range switch. Have you tried starting it in neutral? There's a starter relay in the under hood fuse block you can try to swap it with another relay with the same number and lastly the ignition switch could be bad but this switch usually is not a problem. I hope this helps. Take care. If you have any more questions I can help you with use comment and it will show up in my email please let me know what you' done so far and if you have a test light.
My 2008 chevy Silverado LS won't start I just hear a clicking noise when I try to crank it and the battery seem to be fine
The click sound is the starter selinoid. you can attemt to bypass the selinoid by jumping the two big wires on the starter together and see if the starter spins. But it sounds like your starter is burned up. Time to replace it.
Starter fusible link
wow no year, or even honda car model stated, amazing...but..
crossing what.?
big lug to big
or big to little terminal.
a key fact that......????????
if the starter runs then all fuses are good in the engine bay.
the main starter is not fused anyway. sorry.
if starter cranks engine, with big outside lug jumped to small terminal
that means the KEY line is failing.
the car has A/T or M/T again, i must guess.... sad that.
the M'/T the key line is interrupted by the clutch switch.
the A/T is interrupted by the PRNDL switch on the tranny
all cars can have an alarm system or other BS, that cuts
this line too. (BS like add on remote starts, etc)\
when you turn the key to start, the key line goes to 12v
and must arrive at the solenoid, if not bingo.
its obvious what is wrong, a dead key line.
find it.
a voltmeter (any made in 50 years) finds this in 30min work.
Haing proplems with vipr 150 quad elec start relaced selanoid and battery ust clicks can any1 help
If you jump the selinoid does it crank over ? If yes it's your selinoid if no it's your starter
1helpful
Have put in a new ignition switch and will not put power to the selinoid, when I take a screw driver to the selinoid it just grinds and does not engage starter.
Hi mogan749, jump from the battery to the starter and see if it cranks. I suspect a bad battery or bad connections, I would try this first. Hope this helps. If not please re post.
Do you plug the gernerator into the house and then start it or start it first and then plug it in
The generator should be attached to the gentran switch box then started. Once started, then follow instructions for that system to swich to generator power. Some setups may have their own initiating order, it is important to obtain the correct instructions from your manufacturer and keep them where you can find them in a hurry.
I hope you don't need it too often:)
Regards, Farmerbear at FixYa.com
1helpful
Will not start. Can jump accross the selinoid and
I assume that you are jumping the solenoid in order to bypass an ignition switch that is no longer operating?
If so, did you have the key turned to the run position?
You should not need to bypass any safety switches, just be sure that everything is in the normal starting position. (deck disengaged, in neutral, etc.)
Either way, it sounds like you have a bad ignition switch, or faulty wiring between the ignition switch and the solenoid.
Jul 30, 2009 • Garden
1helpful
1987 F150 302 ci. EFI, Automatic, Was running good. Next morning NOTHING! Wouldn't start or crank over? Just clicking and buzzing, Headlights OKAY. Tried jump starting... NO GOOD. Took battery in... Was...
try over riding the starter relay on the fender ,it has one there right?. dont go to a mechanic yet. the engine aint seized. if it doesnt have this relay then i would get the alternator tested. if you want to test it yourself it can be costly for the right equip. autozone usually tests for free. i dont know were you live so if theres not an autozone. let me know if you cant get it tested.
Top Onan Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you an Onan Electrical Supply Expert? Answer questions, earn points and help others
