On some Galanz models setting the clock is a bit unusual.
You have to press the clock/preset button once then press pause/clear. Now it is in Clock mode setting and you can set the hour then press clock/preset again to set the minutes then press once more clock/prest to finish the operation.
Generally you press clock, type in the time and then press clock again. Galanz have a website where you can download user manual.
According to the manual this is how to set clock.
To set the clock, press "Clock" once or "Timer/Clock" twice (depending on your keypad).
The colon symbol (:) will flash.
Enter time of day. The time appears in the window; the colon continues to flash.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set.
If you need the manual it is on link below.
http://service.us.panasonic.com/OPERMANPDF/NNH624-SET%20UP.PDF
Good Luck
