What makes you think it should?
What options are we talking here?
Chrome , textered , paint to match ,Heated ,power,turn signal, puddle, memory ,auto dim and tow ?
I'm not that far from Berlin that I can't run ya out what ya want/need.
SOURCE: telescoping mirrors
if you tilt the mirror glass and look inside you can see the release tabs, you will have to tilt it different way to get them all
SOURCE: removing radio from 2008 f250
First you will have to remove the bezel around the radio. This bezel will also be from top to bottom. The bezel is snapped into the vehicle. Pry it out very carfully. Clips will be located at the top, middle, and bottom of bezel. Once snapped out, unplug harnesses so that you can easily work with radio and will help with not scrathing bezel. Once the bezel is out of the way, there will be four screws, 7mm or 9/32 use either socket size, that will be holding radio in place. Remove screws and then pull out radio. Use an aftermarket wire harness to make your installation easier. Install bracket and radio using screws removed and resnap bezel in place.
SOURCE: I need wiring diagram for a 1999 Ford f250 side
make your self a jumper set of wires to test with. Find out what makes what move on the old unit,write down the color wire,then apply power and ground to the new unit onw wire at a time.Mark down the color and what function it did.after testing both units then match your research and put the wires together.I wished I were there.Good Luck!
SOURCE: have telescopic mirrors on f250 not enough
I THINK THAT THEY AJUST FROM INSIDE SO YOU WILL HAVE TO REMOVE DOOR CARD TO UNDO POWER CABLE REMOVE MIRROR AND CHANGE AJUSTMENT BENT CHROME LOOKING THING . YOU WILL NEED SOME STAR SCOKETS FOR THE WINDER HANDLE AND LIFT THE DOOR CARD IT SLIDES UPWOODS REMOVE SPEAKER YOU"LL FIND CABLE CONNECTOR THERE. GOOD LUCK
SOURCE: 2008 Ford F250 6.4 turbo diesel, have 3 DTC codes
SUPERSHIPS PROGRAMMER GIVEN ME LOTS OF CODES AND WILL NOT ALLOW MY TRUCK TO STARTiT TURNS OVER BUT CHOKES ITSELF OFF ONE CODE IS P2291
